Here's an article worth reading:
http://www.popularhotrodding.com/tech/0 ... index.html
David "The Wizard" Vizard's hit list looks like this:
15 COMPRESSION BOOSTING MOVES
1. Feed cold air to the induction
2. Keep water as cool as possible (170 F or less)
3. Keep the air cool in the intake ports
4. Put a heat-reflective shine on the outside of the intake manifold
5. Minimize heat transfer through the common exhaust/intake port wall
6. Keep fuel temperatures down (cool can)
7. Run with plugs a little colder than the minimum required
8. Use an ignition system that is gross overkill
9. Utilize as large a spark plug gap as possible
10. Use no more ignition advance than is necessary
11. Maximize quench action
12. Minimize head chamber volume
13. Use flat-top pistons if possible
14. Minimize under-hood exhaust heat--use coated headers
15. Do not ram in but vent out hot air through hood vents
Compression ratio
YJ_and_Corey
- Stroker Displacement: 4.7 and 4.9
- Vehicle Year: 1993
- Vehicle Model: YJ
Re: Compression ratio
I have two guys out there now with 10.6:1 and 10.5:1 SCR on stock ODB1 computers. They are both running the KB 945
They are both running mid-grade pump gas without any detonation issues.
I wasn't aware people were having problems getting more 4.0L compression
No problems to report here...
What is their DCR?
Which cams are they using? A long duration cam could reduce the DCR enough to allow the use of mid-grade fuel.YJ_and_Corey wrote:I have two guys out there now with 10.6:1 and 10.5:1 SCR on stock ODB1 computers. They are both running the KB 945
Which head? The Hesco aluminium head will allow more compression without detonation.
Which plugs?
Any cooling system upgrades?
Jeepinscott
I have a 4.0 with 10:1 SCR and 11:1 DCR.
My max timing is 34 degrees. Pistons stick out -.003 with the .043 gasket I have .040 quench. I have a 100 octane fuel limit and size limit to +.060 bore, stock crank. I tried to stay within the realm of pump gas, but the agressive cam put me into the 95-100 octane range.
I run the Painless Performance Hi-Torque cam and ECM.
It's expensive, yes, but worth every penny. Dyno tuning in Socal on a 'current eddy' dyno cost $300. The Air Fuel Ratio adjusted by the stock computer just doesn't cut it. You can only fool the stock computer so much. I have my fuel trim adjusted for racing, but in what I do had to have economy and reliability. You would be amazed what a properly tuned ECM with a built motor will do. The ECM and tuning added 46 hp, over 25 in just dyno tuning.
You might want to correct your DCR # there(it's always lower than SCR).
YJ_and_Corey
- Vehicle Model: YJ
I only spec one cam for Jeep stroker engines unless it is a race engine. I now have over 15 engines out there.Cheromaniac wrote:Which cams are they using? A long duration cam could reduce the DCR enough to allow the use of mid-grade fuel.YJ_and_Corey wrote:I have two guys out there now with 10.6:1 and 10.5:1 SCR on stock ODB1 computers. They are both running the KB 945
Which plugs?
Comp 68-232-4
That aluminum head is a big waste of cash IMHO.
The big key is in the cooling system upgrade. I make the guys who want the higher compression
run Evans waterless coolant. NO detonation with mid-grade. It negates the possibility of hot spots
developing within the head or block by nature of how it extracts heat and it's "wet-ability" due to a surface
tension significantly less than that of water.
Gimmick? It works, that what I know.
Is the waterless coolant the only upgrade to the cooling systems you use?
YJ_and_Corey
- Vehicle Model: YJ
Pretty much, although I recommend a "ported" thermostat housing as well - increases flow.SilverXJ wrote:Is the waterless coolant the only upgrade to the cooling systems you use?
In my race buggy I am using a Hesco high output pump, but only because the radiator is in the back.
You're not the only one who has that opinion. I think most Jeepers would want to "invest" $2000 of their hard-earned cash elsewhere.YJ_and_Corey wrote:That aluminum head is a big waste of cash IMHO.
I'll have to look into that waterless coolant. Are they still using a stock rad?
For the "gains" on the aluminum head it is so not worth it. Now if they actually did a major change when they made it that may be different.
