GEAR HELP
GEAR HELP
Ok quick question...what all do I need to do to put 4:56 or4:10 gears in my XJ...has D30 and the rear axel I was told was out of a 2000 XJ so it is still Chrysler 8.25. DO i need new carriers and what not?
- wallisek
Re: GEAR HELP
You should not need a new carrier for your 8.25. They come with carriers designed to take gears 2.56 & up. As for your Dana 30, it depends on what gears you have now. The break is at 3.54 so if you have anything lower like 3.07s or 3.54's, yes you will need a new carrier.
2001 XJ 4.0 / 5spd
1986 CJ-7 4.6 stroker project
1979 CJ-5 4.2 resto-mod
1952 Willys M38
1952 Willys M38
Re: GEAR HELP
K thanks...I think thats where i'm having 4x4 issues lol...the when i bought it i had issues with it..so I called the guy and he said the rearend was out of a 2000 xj. and I'm assuming the dana 30 is stock so it's still got 3.07s and the 2000 rearend has 3.55s Any suggestions on where i could get a decent price for 4:56 for them?
- Jeep4xb4u
- Vehicle Make: XJ 2dr
- Vehicle Model: Sport
Re: GEAR HELP
Not sure of the prices, but i have had good luck the two times i have purchased axle parts from them. Good tech service as well.
http://www.ringpinion.com/
88' XJ 2dr
4.0l / AW4 / NP231 / D35c
Re: GEAR HELP
Thanks... I will check them out
Re: GEAR HELP
Yours is a manual? I believe you have to get a bigger carrier for the 30 if you go 3.73 and above. Make sure the rear axle is indeed a chryco 8.25 and not the dana 35(that came in all XJs w/ abs, even if they didn't adapt yours for abs when they put it in). As you know manual 4.0s usually came w/ 3.07 gears and the autos came w/ 3.55s, so you could(did) cause havoc in the transfer case if you try to engage 4WD.
Re: GEAR HELP
Yes mine is a 1996 XJ Sport 4.0l 5 Speed...I don't have abs but I will have to get under it and take a look. I figured somethin was going on when I tried it...The previous owner used it as a bogger/Trail rig...I got it for 1200 bucks so I started doin some remods to get it to a DD. When I had looked at it I tried the 4x4 but I was pretty much in a field and didn't ssem to have a problem (Jeep newbie) With winter here I hit some nasty roads so I engaged the 4x4 and it started pulling left and right and damn near stalled out...if thats the diff gear ratios then I know what I gotta get done...if there could be somethin else up let me know...all the ujoints and whee joints are brand new. But my plan is the regear it to 4:56 with my 4.5 stroker when its done neways.
- wallisek
Re: GEAR HELP
So this will be your daily driver? What size tires are you going to be running with that 5 speed? I run 31's with my 4.0 5spd and have 3.73's. It is a nice combo between power/economy. With 4.56's I assume you will be running around 33+ tires?
2001 XJ 4.0 / 5spd
1952 Willys M38
1952 Willys M38
Re: GEAR HELP
Yea i am running 35's...yes it will be my Daily Driver but I don't go more than 20 miles give a little take a little in a day if that lol
Re: GEAR HELP
My 4.5 Stroker reciope
1994: 4.0 HO block and head new MP springs and decked .001
1981: 4.2 Crank and rods
1999: Intake and 24lbs injectors
Cam: COMP Cams CL68-232-4
Had a very tight budget so I couldn't do much to it.. I don't know if I will get much out of it but It was worth a shot lol Will it work.
PS: I spent $400 for the whole thing including the new cam
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 1 guest
