IAT Relocation
Stroker Displacement: 4.9
IAT Relocation
Post by jsawduste »
Want to move my IAT from it`s current position. Now it in the intake manifold itself. So it is seeing a relatively high temperature.
IIRC it is the coolant sensor that changes loops as the engine warms, right ?
A picture of my intake.
Picked up a stainless bung with the 1/8 NPT. Thinking that mounting the IAT close to the AC will work best. Comments or thoughts ?
For those that have stand alone tuners. What impact has the IAT had on timing or mixture ?
Any thoughts on what I should expect with this relocation ?
THANKS
Re: IAT Relocation
I would still keep it in the intake tract, possibly as close tot he filter as possible.
Re: IAT Relocation
I have mine relocated in my homebrew FIPK heatshield so it sees air that's as close to ambient temp. as possible. Theoretically it should slightly advance the ignition timing and richen the A/F mixture for better performance but I don't have any measurements to substantiate it.
YJ_and_Corey
I think I'll order a "tab"
Stroker Displacement: 4.7 and 4.9
Vehicle Year: 1993
Vehicle Model: YJ
Re: IAT Relocation
Post by YJ_and_Corey »
That is obviously a YJ engine bay, and thus ODB1.
Leave the IAC right where it is.
Go to the local junkyard and grab an XJ 4.0L computer from 91-96, from a vehicle with an automatic.
It's a bolt in.
It will give you the timing advance you are looking for, and it's good for about 15 ponies over stock.
Jeep added timing to that computer to make up for the parasitic AW4 power losses.
YJason
Re: IAT Relocation
Post by YJason »
YJ_and_Corey wrote:That is obviously a YJ engine bay, and thus ODB1.
It's a bolt in.
96 XJ is OBDII
YJ_and_Corey
Vehicle Year: 1993
Vehicle Model: YJ
Re: IAT Relocation
Ok, 91 - 95.5 then
Good for you, you spotted a boo boo
Re: IAT Relocation
Post by jsawduste »
It's a bolt in.
Thanks Corey,
I`ll do just that.
BTW Good luck with your new projects. They look great !! :cheers: Maybe share over here ?
YJ_and_Corey
Vehicle Year: 1993
Vehicle Model: YJ
Re: IAT Relocation
What did you have in mind for sharing?
Re: IAT Relocation
Post by jsawduste »
YJ_and_Corey wrote:What did you have in mind for sharing?
Maybe the stroker kit from PBB ??
YJ_and_Corey
Vehicle Year: 1993
Vehicle Model: YJ
Re: IAT Relocation
That would work for me, I'd buy a vendor star or whatever. They are brand new cranks after all....
BADASYJ
Re: IAT Relocation
Post by BADASYJ »
It's a bolt in.
Does this only apply to manual YJs only or would there be a gain with an automatic YJ as well?
