Header choice on a 4.7 MJ build
1BADMUDR
Vehicle Make: JEEP
Vehicle Model: COMANCHE
Post by 1BADMUDR »
alrighty, i am down to header choices and I still am confused as to which one flows the best. It seems the Borla 17039 has changed design and was no longer recomanded by Hesco. they suggested i look into the JBA1526S header. it seems this one has 1.5" primaries with a 2" collector. i have one coming next week just to take a look at it and see if it would work.
Does anybody have a good recomendation besides the junk APN headers. I just cant justify putting on an inferior product in a high fail rate application. I would rather utilize a brand I sell so warrantys are not a problem if needed. I would like to know what part numbers people are using for the split header design with two 2' collectors.
YJason
Re: Header choice on a 4.7 MJ build
Post by YJason »
I run a Borla 17202 heat wrapped to the collectors into 2-2" pipes into a 3" pipe to a 50 series flomaster, then 2.5" out the back.
1BADMUDR
Vehicle Make: JEEP
Post by 1BADMUDR »
what vehicle do you have that header in?? is it a cherokee or comanche? I am curious about it fitting in my slammed MJ utilizing a 94 block and head witha 00 XJ intake.
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
Why are APN junk inferior products? Ive read more of borlas cracking and my APN has held up just fine for a few years now....
97 XJ 4.6
90 MJ 4.0 - sold
YJason
Post by YJason »
1BADMUDR wrote:what vehicle do you have that header in?? is it a cherokee or comanche? I am curious about it fitting in my slammed MJ utilizing a 94 block and head witha 00 XJ intake.
Its in a YJ but they are short headers. They are made to have catalytic converts bolted to the bottom of them. I have mine running in front of the oil pan and doesn't hang any lower than the bottom of the oil pan.
lazybaka
Vehicle Model: cherokee
Post by lazybaka »
where have you read about borla's cracking ?
YJason
Post by YJason »
I've heard that the Borla headers that are similar to the factory headers crack in the same place near the collector.
YJason wrote:I've heard that the Borla headers that are similar to the factory headers crack in the same place near the collector.
Some Borla headers have indeed cracked and a bad driver's side engine mount is often a contributing factor. I've had mine for 12 years and 156k miles with no problems.
yuppiexj
Post by yuppiexj »
A regular splashing of cold water during stream crossings tends to shorten the lifespan a bit.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
