Broken 4.0L piston
brewmenn
Broken 4.0L piston
Post by brewmenn »
My engine was making a knocking sound, to I dropped the pan and found this...
Just wondering how common this is. I looked at the pistons I pulled from my '98 4.0 and 5 out of 6 had the start of the same failure.
I don't remember the year of this particular engine and the mileage is unknown.
Flash
Re: Broken 4.0L piston
Post by Flash »
WOW!!!!!!!!
And not even a stroker!
Damn, they must've used the bad batch on your 4.0(or someone didn't take care of it to well).
Shark
Consistent
Consistent
Post by Shark »
heres a problem i had a while back.
'95 XJ 4door 4.0 aw4 2" 31's
Flash
Post by Flash »
tigerShark wrote:heres a problem i had a while back.
A picture like that, NEEDS, a story to go along with it :o
Flash
Shark
Consistent
Consistent
Post by Shark »
not too much to tell. had a hairline in my head gasket next to my number 1. caused it to run lean. my fire power ignition kit burned a hole in the piston.
Meh.. weak.. all of you..
That is the entire piston. Nothing left in the block but the rod.
To the OP, did you have any odd noises or abuse your 98 engine in anyway?
Sinbad
Post by Sinbad »
The first pic is what happend to mine. SOOOO I now have a 4.6
Caused by a worn cylender bore.
bratcop
Stroker Displacement: 4.5L
Post by bratcop »
I had a piston in my 2001 4.0L that looked exactly like that...was one of the middle cylinders, bought it that way at a deep discount....not sure how common, but we must have had something in common because it looks exactly the same as yours :doh:
2001 GC Laredo
4.5 Stroker, 9.6 SCR, 8.1 DCR
Stock Valvetrain
24# Cobra Injectors
Bored Throttle Body
CAI
Ported and Polished 0331 Head
Zeitroniz WideBand O2 logger
Sailor77
Vehicle Year: 1999
Vehicle Make: JEEP
Vehicle Model: GRAND CHEO
Post by Sailor77 »
Revival!!!
I have a 1999 WJ with the same thing. Just talked to another fella who has an 2000 WJ with a shattered piston. So between cracked heads and cracked pistons, the later 4.0 is not all its cracked up to be.
basscat
Vehicle Model: TJ Sport
Post by basscat »
Same thing happened to my 4.0 at 230,000 miles.
mtmech
Post by mtmech »
that samething happened to my 97 tj. to my #6 piston. only thing thats left is the rod and wrist pin.
