Lifter comparision?
Re: Lifter comparision?
That must have been prior to Johnson's purchase by Topline/others (whole history behind that). From what I found the lifters with "Johnson" Printed on the side are old and good. I don't know who makes the Sealed Powers or Clevites today. Mine don't have "Johnson" Printed on the side, but i do know whey are made in the US. Nor do I have access to one to compare to my library of lifters..lol
George Dickel
Post by George Dickel »
I've heard on several occasions that there are only 2 or 3 companies even making lifters anymore. Your work here appears to disprove that unless the same 2 places are turning out 2-3 variations each. Nice job.
'98 Wrangler Sport, 4.6L Stroker
'04 Mustang GT, 4.6L with a few bolt-ons
Only 2 places in the US that may be making lifters. There is still a bunch of over seas lifters.
crazygogo
Stroker Displacement: 242 + .30 over
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
have you heard of sealed power ht2011R and is it different from ht2011 ? what is the R for?
6TIME
Consistent
Consistent
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
crazygogo wrote:have you heard of sealed power ht2011R and is it different from ht2011 ? what is the R for?
The R indicates that it's a lifter intended for use higher revving applications where it will resist pumping up. Steer away from Sealed Power and OEM replacement lifters for this application. The quality control on these particular lifters is inferior and many are manufactured in Mexico.
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
thank you 6TIME for that info.. so knowing this.. what lifters are the best to go with ?
6TIME
Consistent
Consistent
Vehicle Year: 1993
Vehicle Make: JEEP
Post by 6TIME »
As stated by others on this forum... stick with Johnson/Hylift who is owned by Topline or use factory Mopar tappets. I've contacted Crower and they said they source their lifters from Johnson. I've been using Crower lifters in all the Mopar/Jeep builds I've done lately with good success. The "2011" lifter part number should be avoided. I have no idea why but, I've seen some very poor machining and inconsistent quality control with these particular lifters. Good luck.
6TIME wrote: The "2011" lifter part number should be avoided. I have no idea why but, I've seen some very poor machining and inconsistent quality control with these particular lifters. Good luck.
That is the same part number that Johnson uses.
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
you guys are oh so helpful and i just don't want my 1st jeep engine build to go wrong..
6TIME
Consistent
Consistent
Vehicle Year: 1993
Vehicle Make: JEEP
Post by 6TIME »
Thx for the correction... I meant to say any 2011 from all parts stores and Aftermarket suppliers except for Crower and Johnson. The Mopar guys are having the same problems with these lifters.
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
so factory lifters that come with P4529229AC purple cam are bad? or there great? if need be i will buy new lifters.. i got the cam NIB off ebay for 60
FWIW, the MOPAR lifters that came in my 229AC have been working fine.
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
THANK YOU and i guess i will use them.
