rear wheel bearing removal
Exos
Anyone has a trick to remove the rear wheel bearings on a Chrysler 8.25? The manual states a special tool, but there must be another way?
Re: rear wheel bearing removal
If it's the one pressed in the axle tube you'll need a BIG slide hammer and the wheel bearing tool of the correct size to get it out, then the new one can be driven back in with a BIG socket and a BMFH.
