throttle body size
StroktWJ
Vehicle Model: Grand Cher
Re: throttle body size
Post by StroktWJ »
So the verdict looks to be the 62mm.
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
StroktWJ
Post by StroktWJ »
I noticed there seem to be 2 different techniques when boring the 4.0L throttle body. Some shops only cut below the butterfly and reuse the oe butterfly, some cut the whole bore and use a new aftermarket butterfly.
What do you guys think about each or what do you think a mildly daily drivern stroker that does very little off-road and pretty much pulls a boat a few times a year?
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
Depends how much you want to spend. Going through the butterfly means a new butterfly plate will be needed.
StroktWJ
Post by StroktWJ »
strokedjeep sells a throttle body fully bored with new plate for $90 + $70 core up to 63mm. I would be sending my TB in so there would be no core. Other sites are the same price and still using factory butterfly. I can't wait I just got the truck running great put a new upstream o2 sensor,cleaned the IAC and it runs like a different animal.
Next the 63mm throttle body, 26lbs injectors then sbc valves and a more aggressive camshaft.
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
aaronkeiser
Vehicle Year: 1991
Post by aaronkeiser »
I should point out that i recently went from Double platinum NGK plugs to some Champion RC9's and it made my ping go away completely and made my sensitive throttle much more manageable.
I'm bout due for some new rc9s. Though some people have me curious about the obd2 Jeeps liking ngks--a combo I've never tried(I really liked the autolites in the 96 pre-stroker).
