Ignition Parts
laxplayermjd
Ignition Parts
Post by laxplayermjd »
So im am about to fire up the stroker in the next couple days. i went with the standard champion plugs everyone seems to be running.
My xj is an 88 renix what id like to know is as far as the cap, rotor and spark plug wires goes are they really any different??
Ive looked and looked and all part numbers are different between the 88-90 and 91+. but are they really, is it better to just get 91+??
I know the distributors are different . i was just looking at maybe some accel wires i found on ebay for cheap, but does it depend on what year i should look for to fit the 4.0. it seems most of the performance parts wise, coils and wires etc dont have the 88-90 application.
BMW Master Tech
ASE Master Tech
Even BMW guys need a toy.
In process 4.6l Renix Build.
shawnxj
I love this board
I love this board
Vehicle Model: cherokee
Re: Ignition Parts
Post by shawnxj »
and to add to his question. i have a 99 block going into an 88 xj which year distributor should i use?
laxplayermjd
Re: Ignition Parts
im using the 88, due to the different ignition systems i dont think you could use a 99 without a full harness swap to a newer year
BMW Master Tech
ASE Master Tech
4.whoa
Vehicle Model: xj&mj
Re: Ignition Parts
Post by 4.whoa »
The 4.0 distributors swap renix to HO. I'm using a 94 dist in a 90 block now. same-same. the caps n rotors and wires also swap between them. although the later models have a different style rotor -late 95 and up iirc :cheers:
edit: :doh: There is one plug wire difference that matters -the coil wire. the renix coil is on the fender not the block, so it needs to be longer
-Russ
laxplayermjd
Re: Ignition Parts
after researching some more, it appears the cap and rotors are interchangeable for renix and 91+ .... autozone lists same parts for different years
the plug wires are different. it seems the only difference is a couple of the wires on the 91+ have two 45 degree boots on the spark plug ends, the renix all are straight
Can anyone verify?
Acell wires are quite a bit cheaper for the renix than the 91+
BMW Master Tech
ASE Master Tech
laxplayermjd
Re: Ignition Parts
so then the the only difference in the renix to ho distributor is the location where the harness comes out?? all the indexing distributor links i see are not set up like mine, then again maybe i dont have original distributor either
BMW Master Tech
ASE Master Tech
4.whoa
Re: Ignition Parts
Post by 4.whoa »
The distributors will interchange IN THE BLOCK without issue, however you need to use the one for the same system you're running be it renix, obd 1,whichever.
-Russ
