ok here it goes. Purchased a 4.7 stroker block running a 12w 258 crank and what looks to be the KB dished aluminum pistons. Unsure of cam specs but its similar to the xtreme 4x4 cam for these motors. Stock refurbished HO head and intake running 24lb ford injectors and controlled by factory renix junk. heres the issue im at right now.
will start and idle rough when revved you can hear it missing by way of lowered rpm but its running smooth and no smoke or any other ugly symptoms. once the tps is calibrated right it will idle very rough and very low, it will then begin to cycle idling very high and smooth to falling on its face and stumbling sometimes causing it to shut off, carb cleaner to check for vac leaks but cant find any weve replaced or checked everything we can but it still does the same thing over and over... ive got a big ride in 3 days and unless i can get this licked im gonna be out of a jeep for the biggest event of the year
__________________
help PLEASE 4.7 wont run right in a renix!
xjdoug
- Vehicle Year: 1987
Re: help PLEASE 4.7 wont run right in a renix!
Sounds like the distributor indexing is off. Go to http://www.angelfire.com/my/fan/dist_index.html for details on how to reset it.
