Needed Gaskets?
sudo chop
Needed Gaskets?
Post by sudo chop »
The machine shop is almost done with my parts, and I am trying to get all of my stuff together so I can get it done quickly when it comes back. This is my first time doing this, however, and I am not sure what gasket set(s) to buy to get all of the seals and everything I need. Do I just need a head gasket set and a conversion gasket set? Also, what brand is best and where should I buy? Are there differences between the years? The block I am using is a 53010449 casting and the head is 0630, from a 99. Thanks
Bodo
Re: Needed Gaskets?
Post by Bodo »
Get the Headset that matches the head and the Conversion Set that matches the block.
sudo chop
Re: Needed Gaskets?
Post by sudo chop »
So that will be all I need then? Whats the best brand to get?
Bodo
Re: Needed Gaskets?
Post by Bodo »
Yup, that's all you need. I purchased Fel-Pro gaskets. I even got a few extra gaskets that i didn't end up using. I think there were two styles of water pump gasket...
Re: Needed Gaskets?
I recommend VICTOR gaskets, the head gasket is thinner so it will help the quench and the manifold gasket is graphite mesh, they seal better than ANY manifold gasket Ive ever seen from Felpro for an AMC six.
sudo chop
Re: Needed Gaskets?
Post by sudo chop »
Ok, cool, thanks. Can you tell me where I can find victor reinz gaskets? I cant seem to find a retailer searching online.
4.whoa
Vehicle Model: xj&mj
Re: Needed Gaskets?
Post by 4.whoa »
I had machine shop get them for me but iirc carquest carries them.
-Russ
