new stroker build about to happen. some questions to ask...
kylerobb1
Vehicle Model: Grand Cher
Post by kylerobb1 »
i know there are plenty of posts out there like this. but i got questions and can't find the exact answer i'm looking for. i'm in highschool and need to keep this as CHEAP as possible, and run on 87. i will use the yj crank and rods. i'm not building a race engine here, just something with some pep to it :D
1. what is the maximum compression ratio i can run while running 87 octane? if i cant run 87 all year round i wont build this engine.
2. what all needs to be machined on the engine to make this happen and what would be a figure money wise that i'm looking at? i know i'll have to bore .30 over and machine the usual bearings and such. but decking? head? i also know i'll need to cc the head. thats fine.
3. also any pointers on quench would be appreciated.
thank you so much guys
kylerobb1
Re: new stroker build about to happen. some questions to ask...
Post by kylerobb1 »
oh and i'm keeping the head stock, just wanted to know about machining on it. also the cam will stay near stock.
I run mine (9.25:1 CR, 0.088" quench) on 87 octane during the cooler months when it's less than 90*F outside.
92tank
Stroker Displacement: 4.5
Post by 92tank »
I DID THE SAME BUILD, BUT NOT 30 OVER. MINE WILL RUN ON 87, BUT I RUN 89 JUST BECAUSE. AND I DIDNT DO ANY MACHINE WORK TO IT, AND RUNNING THE STOCK CAM WITH 183,000 ON IT. RUNS GREAT THE ONLY THING THATS NOT STOCK IS GOING TO BE THE INJECTORS, IF THEY EVER GET HERE. DAMN HOLIDAYS GOT THE MAIL ALL SCREWED UP!
Mopud
Stroker Displacement: 4.66L
Vehicle Model: TJ
Post by Mopud »
What's the deal with petrol (gas) for your guys in the states? It seems quite low octane, the minimum octane fuel here for us here in Australia is 91 with additional choices of 95 and 98 at every pump. Even our diesel gets the high octane treatment!
I can advise that decking/machining the head can be worked out once you know what compression ratio you want to run in conjunction with gasket, piston and rod (using yj i see) selection. It's too hard to advise how much to deck off the block or shave off the head when you don't have any other parts chosen just yet. A good start once you start to get everything together is to use the Stroker Compression Ratio Calculator on this site (just to the right and below the banner up the top).
I can't tell you estimates on cost because i'm in Aus but I will be getting my parts back from the machine shop next week and can spill what I paid with a service breakdown if it will help any.
Dino's a bit of a legend around these parts and he would have a build up to suit your budget, try the recipes section of his holy bible of an amc stroker site at http://www.jeep4.0performance.4mg.com/stroker.html. Perhaps the low budget rockcrawler or poor man's stroker set-up will suit you.
Good luck with your build Kyle.
Regards,
Mopud
2001 TJ 4.66L
Mopud wrote:What's the deal with petrol (gas) for your guys in the states? It seems quite low octane, the minimum octane fuel here for us here in Australia is 91 with additional choices of 95 and 98 at every pump. Even our diesel gets the high octane treatment!
The octane ratings are just calculated different. US is RON+MON/2. Outside it is usually just RON. http://www.btinternet.com/~madmole/Refe ... ONPON.html explains it better plus has a rough chart at the bottom comparing the grades.
Mopud wrote:Dino's a bit of a legend around these parts and he would have a build up to suit your budget, try the recipes section of his holy bible of an amc stroker site at http://www.jeep4.0performance.4mg.com/stroker.html. Perhaps the low budget rockcrawler or poor man's stroker set-up will suit you.
If I ever come to Perth I'm gonna look you up mate and have a beer with you. :D
Mopud
Vehicle Model: TJ
Post by Mopud »
Haha i'll be here! The beer might come sooner though if i stop by your neighbourhood while I'm on the way to Greece next year. I always fly Emirates :cheers:
2001 TJ 4.66L
Are you Greek?
Mopud
Vehicle Model: TJ
Post by Mopud »
Yes I'm a Greek born in Australia. With my surname Zorbas, it's pretty much a given.
I'll be in Greece next year to complete my service!
2001 TJ 4.66L
Mopud wrote:Yes I'm a Greek born in Australia. With my surname Zorbas, it's pretty much a given.
Ela vre paithaki mou. :cheers: You'd better stop by Dubai on your way.
tdkask
Vehicle Year: none
Vehicle Make: XJ
Vehicle Model: undecided
Post by tdkask »
Cheromaniac,
I didn't realize there were members here from Dubai. I am a very new member, as you can see here, and was JUST in Dubai for a few days. I would have gladly met for a beer and to see your rig. :) Ohh well, that's how it is, I guess.
tdkask wrote:Cheromaniac,
Me too. I could have taken you for a ride in my Jeep and shown you how Jeeps can do donuts. :lol:
Mopud
Vehicle Model: TJ
Post by Mopud »
Malista file mou! tha se dw kai tou xronou sto Dubai!!
2001 TJ 4.66L
tdkask
Vehicle Year: none
Vehicle Make: XJ
Post by tdkask »
Cheromaniac wrote:Me too. I could have taken you for a ride in my Jeep and shown you how Jeeps can do donuts. :lol:
Yeah, the dunes would have been a blast, too, I bet!
