Royal Purple Assembly Lube
SkylinesSuck
Post by SkylinesSuck »
I'm sure it's just fine for bearings and stuff, but I've been told the guy putting my motor back together wants to use this for EVERYTHING. Would this be sufficient for the cam lobes/lifter faces, or should he be using some kind of moly paste stuff? Does anybody know if the CompCams people usually throw a small tube in the box like crane used too? Thanks!
Re: Royal Purple Assembly Lube
Use moly on the cam.
