I started building up my stroker today, checking ring gaps, bearing crush etc and noticed the new cam bearings installed for me by my machine shop.
I was intrigued by their design and difference and wanted to know why they were made that way.
The first bearing has a small groove and an oil hole.
The second cam bearing has no groove but an oil hole.
The third has a much wider groove than the first and two cut oil holes except one of them meets the block face and goes nowhere whereas the other one goes through to the oil gallery like the others.
The fourth one is identical to the second.
Does anyone have an explanation of the differences in these bearings and why they are designed so?
Regards,
Mopud
As a side note the machine shop did take my camshaft and checked to make sure it fit right after they'd prepped it and installed the cam bearings.
Just a question out of curiosity on cam bearings
- Mopud
- Stroker Displacement: 4.66L
2001 TJ 4.66L
- Mopud
Re: Just a question out of curiosity on cam bearings
Can only attach 3 images
2001 TJ 4.66L
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
cylinder walls look great, cant speak on the cam bearings though.
I heard the that #3 has the ID groove to provide oil to that second hole. Supposedly there is an older engine that uses oil off that #3 to oil the shaft rockers. I have no idea why #1 has a groove. Maybe to provide more oil to the cam gear.
Your #2 looks kind of beat up.
- Mopud
It does look kind of rough but i assure you they're just scuff marks (it's not scored in anyway), it's in A1 condition.SilverXJ wrote:I heard the that #3 has the ID groove to provide oil to that second hole. Supposedly there is an older engine that uses oil off that #3 to oil the shaft rockers. I have no idea why #1 has a groove. Maybe to provide more oil to the cam gear.
Thanks for the info and yes I agree the cylinder walls are ace, i'm very pleased with the work!
2001 TJ 4.66L
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 2 guests
