GT4202
Shorco
Vehicle Make: 1996
Vehicle Model: cherokee
GT4202
Post by Shorco »
First I want to say Hi to all of you. This is a great site . I thought I would share some pics of my jeep cherokee stroker & turbo GARRETT GT4202
Part Description:
stroker 4.7L
Ross Forged piston Bore. 3.905" Dish -30
Total Seal Gapless
Connecting Rod Eagle 6.125"
Mopar Head gasket
Mopar Performance Double Roller Timing chain
Port & polish Cylinder Head
Mopar valve spring Kit .525" lift
COMP Cams: 68-239-4
505 performance Stainless steel Valve Coating For turbo
TURBO Garrett GT4202
Tial wastegate 44mm
Tial BOV 50mm
Precision Intercooler 750hp
Bosch Injector 1680cc
DENSO Double Fuel pump
ACCEL DFI Wideband control Unit
I Leave you with pictures
FORGED PISTON
EAGLE CONNECTING ROD
Install New Crankshaft
:banana: Finish Build block
My New turbo Garrett GT4202 T4 Exhaust 1.01A/R :rockout:
Tial Wastegate 44mm
Installation Intercooler
Fabricate Exhaust Manifold at my House
Installation Wiring
Finish :wiggle:
ACCEL DFI
shawnxj
I love this board
I love this board
Re: GT4202
Post by shawnxj »
so how about some specs and how do you like the accel dfi? i'm considering using that if i don't go with the megasquirt
Shorco
Vehicle Make: 1996
Re: GT4202
Post by Shorco »
The Accel DFI system is excellent. Easy to use, and can manage everything in the way you want. Good for turbos, Nitrous or supercharger.
See the link some specs
http://www.jegs.com/p/DFI/Accel-DFI-Thr ... 1/10002/-1
the_wrench116
Re: GT4202
Post by the_wrench116 »
how long till you blow up the trans? what kind of hp and tq # did you get?
Shark
Consistent
Consistent
Re: GT4202
Post by Shark »
How do you like that Hurst shifter?
'95 XJ 4door 4.0 aw4 2" 31's
Re: GT4202
You typed that you were using the 6.125" eagles but your pics are of the 6.150"s--hopefully you made calculations based of the 6.150" length.
Shorco
Vehicle Make: 1996
Re: GT4202
Post by Shorco »
trans still is good >> now 8-9psi of boost 368rwhp ,,, 392tq . My plan now to go to more boost 15-18 psi
Shorco
Vehicle Make: 1996
Re: GT4202
Post by Shorco »
gradon wrote:You typed that you were using the 6.125" eagles but your pics are of the 6.150"s--hopefully you made calculations based of the 6.150" length.
Yes you said is true,, I wrote by mistake
when I bought Eagle connecting rod comes with it info sheet this is written in it 6.125"
I know the true 6.150" length.
Shorco
Vehicle Make: 1996
Re: GT4202
Post by Shorco »
Hi
I done my DYNO befor some days with 12 PSI of BOOST, and I got 497 WHP & 570 TQ
see the DYNO video and reply to me
http://www.youtube.com/watch?v=iGk_CAVZfZI
Best of luck for you
Re: GT4202
Sounds bad ass.
In the pics I see a stock PCM, how does the Accel DFI tie into it?
ca2a18
Stroker Displacement: 4.0L
Vehicle Make: Wrangler
Vehicle Model: sahara
Re: GT4202
Post by ca2a18 »
:cheers: very nice project bro
Best of Luck
Shark
Consistent
Consistent
Re: GT4202
Post by Shark »
The manifold is gorgeous! Btw, it looks like you're putting that beast together in a shower room.
wafi
Stroker Displacement: 42305
Vehicle Year: 2001
Vehicle Make: 2001
Vehicle Model: 2001
Re: GT4202
Post by wafi »
ماشاء الله
ياليت يالغالي تفيدني وين شاري او مفصل القزوز للضرورة
Shorco
Vehicle Make: 1996
Re: GT4202
Post by Shorco »
هدا حسابي في الفيس بوك حياك يالغالي
Tameem AlAsaif
Re: GT4202
Nice numbers! I don't know when my brother will end up building his turbo'd 4.9l stroker with mostly 505 parts, but know the results will be up there as well. Question: Are you in fact using 1680cc injectors? That equals 160#, which seems to be 100#+ too much. Do you know what the duty cycle is during WOT?
