Crate Stroker Suggestions?
CodeRed30
Stroker Displacement: N/A
Post by CodeRed30 »
I just blew the tired Renix 4.0 in my XJ and figured it'd be a good time to just upgrade to a mild stroker. However these are my questions-
1. What is a reputable crate motor builder for Jeep strokers?
2. Should I be looking to change to the H.O. heads/cam/intake mani or stay with the Renix? And if I should make the H.O. switch, what needs to be done to make the Renix stuff work with it?
3. I'm not looking for crazy power, just reliability and a bit more power. Therefore, should I be looking at a 4.5, a 4.7, or a 4.9?
Thanks in advance for any insight you guys can give!
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Re: Crate Stroker Suggestions?
Post by amcinstaller »
what is your budget, mechanical level and intended use for the engine?
1. Hesco are the best but also the most expensive, followed by Golen. Avoid Titan.
2. Depends on which state you live in. If it's CA, just buy a stroker short block and bolt your Renix head plus other hardware onto it. If you make the HO switch you'll need the HO intake manifold (preferably '99+) with TB and injector rail, HO header, '91-'95 HO fuel lines, and Ford 24lb injectors. You'll also need to modify the Renix TPS to fit on the HO TB.
3. Go for a 4.6. The cylinders will have been bored +0.030" so they'll be straight and true, and there'll be enough meat left in the cylinder walls for a second rebore should it become necessary.
CodeRed30
Post by CodeRed30 »
Sorry, should've thrown that in the first post.
Budget- Under $3k for the longblock
Intended use- 80% street // 20% Offroading MAYBE a tow once in a great while. Maybe...
Mechanical level- I'm fairly confident in my abilities, and have some solid experience under my belt. However, I wouldn't be savvy to building a stroker from scratch, hence the crate motor.
CodeRed30
Post by CodeRed30 »
Cheromaniac- Is the HO swap worth the extra work? Also what model heads should I be looking for? I've heard some are better than others, for both the Renix and the HO
Hesco, Golen, and ATK are both good. Hesco is probably the best but you need a thick wallet with them.
CodeRed30
Post by CodeRed30 »
Google found me Speedomotive also...
CodeRed30 wrote:Cheromaniac- Is the HO swap worth the extra work? Also what model heads should I be looking for? I've heard some are better than others, for both the Renix and the HO
Where are you located? What are your state's emission regulations? Converting to HO would eliminate the EGR so you might want to check if it'll be legal.
CodeRed30
Post by CodeRed30 »
I'm fortunate enough that I don't have any emissions testing where I live.
Then get a '91-'95 HO head, port it, add the other parts that I mentioned, and enjoy the extra power. :D
CodeRed30
Post by CodeRed30 »
Sounds good, but what else will I need? I'm sure the Renix intake mani and TB won't work, right? What about all the Renix sensors and wiring connectors?
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
CodeRed30 wrote:Sounds good, but what else will I need? I'm sure the Renix intake mani and TB won't work, right? What about all the Renix sensors and wiring connectors?
Read item 2. from my first post. It's not difficult to modify the Renix TPS to fit the HO TB but if you're not confident doing it, Hesco have an adapter.
4.whoa
Vehicle Model: xj&mj
Post by 4.whoa »
Cheromaniac wrote: but if you're not confident doing it, Hesco have an adapter
that is the easy way,but holy cow are they proud of themselves!!
-Russ
Yeah, I don't think anyone could accuse Hesco of selling anything too cheap, especially their TPS adapter at an eye-watering $145. :lol:
http://www.hescosc.com/shop.asp?action= ... catId=7541
Users browsing this forum: Bing [Bot] and 5 guests
