Machining: Do I need all of this?
Ruffestneckaround
Post by Ruffestneckaround »
I'm trying to get a feel for machine shop prices before I start buying parts, it looks like this is going to double my investment. 2 questions here, do I need all of these services? 2. Are these decent prices? (In Canada)
This is the response to my inquiry, which included a lot less work...Thanks
"Here are some prices on the machining for a straight six.
Clean Block--(Bake and blast, includes R&R frost plugs and cam bearings)--- $166.43
Magnaflux--(Check block for cracks)----------------------------------------------- $ 75.00
Align Hone Main Bearing Saddles--(Needs to be done before decking)-------- $277.99
Check Main Bearing Clearances--(Recommended)------------------------------- $ 90.00
Bore & Hone Cylinders--($35.00 each hole)-------------------------------------- $210.00
Deck Block Surface----------------------------------------------------------------- $117.30
Check Rod Housings & Bearing Clearances--------------------------------------- $ 71.40
Resize Rods--(If needed, includes checking for straight/shotpeening)--------- $126.00
Balance Rotating Assembly--(Recommended)------------------------------------ $350.00 approx (may vary due to rotating assembly used)
Install Piston on to Rods--(Assuming you are going with full floating style)---- $ 50.00
Install Crank & Pistons--(Based on 4 hours shop time)---------------------------$340.00
As for porting the head it will vary with the amount of work needed. As an example a pair of V8 heads is usually around $800 for a street porting job.
You can supply your bearings however we do prefer you supply a quality brand such as Clevite or Federal Mogul.
Cam bearings would cost $50 for Clevite bearings.
We definitely stand behind our work and any problems are judged on a case to case basis."
-Dusty
Bodo
Re: Machining: Do I need all of this?
Post by Bodo »
Here is what my machine shop charges in USD:
Ruffestneckaround wrote: Clean Block--(Bake and blast, includes R&R frost plugs and cam bearings)--- $166.43
$45
$40
Don't know what you need the align hone for decking, BUT: $125
included in assembly
$100 6-cyl
$100
$120
$200 b/c no bob weights needed
$48
$400 for assembly (includes checking clearances.)
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
i can only speak to a couple thingd on that list. to hot tank magnaflux and fully check two blocks (first one was bad), and clean rods and remove pistons, and grind but not polish crank i paid 250 bucks cdn. another shop (the first closed down a month after i picked up my block, crank, rods and pistons) wants 35 bucks a hole for boring.
Unless they check the block and find the main tunnel out of line it doesn't need to be align honed. Balancing should be cheaper as no bob weights are used and this takes a considerable amount of time. Checking bearing clearances, installing pistons in block, installing crank and cam in block and timing set are all part of assembly.
Alex22
Consistent
Consistent
Post by Alex22 »
I don't see why the block needs to be align honed before it can be decked. They most likely said it that way because they don't want to scratch the deck while align honeing the mains, just an order of operations thing. If the block is being align honed then the main bearing clearances and housing bores need to be checked while that is being done. It is priced as one job where I work.
~Alex
woodjeep
Post by woodjeep »
I would install my own crankshaft and rods/pistons. A ring compressor tool is cheap and it only takes an hour or two to install the crank and connect everything
Ruffestneckaround
Thanks guys!
-Dusty
Users browsing this forum: mpgMike, Semrush [Bot] and 5 guests
