How much are you going or did you spend on your stroker?
How much do you plan to spend or did you spend on your stroker?
Less than $500
11
3%
$500-$1000
27
8%
$1000-$1500
41
12%
$1500-$2000
38
11%
$2000-$2500
51
15%
$2500-$3000
50
14%
$3000-$4000
56
16%
$4000-$5000
26
7%
$5000 +
27
8%
I bought a complete motor for about $2,000
3
1%
I bought a complete motor for about $3,000
3
1%
I bought a complete motor for about $4,400
9
3%
I bought a complete motor for about $5,000
1
0%
I had a custom motor built for me and spent more than $5000
6
2%
Total votes: 349
Shark
Consistent
Consistent
Re: How much are you going or did you spend on your stroker?
Post by Shark »
Muad'Dib wrote:Try this thread:
viewtopic.php?f=5&t=749
wow, there goes the sub $500 build cost if much machine work is needed. almost makes me feel just replacing the crank and bolting everything back up. i know theoretically this is a horrible idea but has anyone actually tried it? sure would be dirt cheap. cranks are 29.99 at my local JY.
'95 XJ 4door 4.0 aw4 2" 31's
Plechtan
Post by Plechtan »
I guess it depends what you want to end up with when you are done. Just replacing the crank and bearings should work, You should at least measure the crank to see what size bearings to use. Maybe grind the crank. But if you start with an engine with 100,000 miles on it you are going to end up with an engine with 100,000 miles on it. If you go through everytning you should end up with an engine that will be like new.
Peter Lechtanski
I've swapmeeted/Fleabayed/Craigslisted been given enough parts that I could have one running by the end of the week for what ever it cost to get my Renix block bored!, but I'm going to build one the right way, it can be done cheaply! the only money I plan spending on machine shop work is boring, block decking and grinding the crank. I own my own cam bearing installer and valve grinding equipment and have all the specialty assembly tools!
Heck
Post by Heck »
I'm voted for 1500-2000, but that's cheating and wishful thinking, since I didn't like the way the first one came out, and had lots of fun, so I did it again.
About 900 for machining, 550 for the pistons, 100 for the crank, 300 for cam, gaskets, and etc. Plus an oil pump and timing chain, so that puts it above 2000 already, and I know I don't remember some stuff. Oh yeah- Fuel injectors, valve springs, bearings, 2 broken bolts, rod bolts, the upcoming fuel/air meter (waiting for the LM-2 iPod touch version).
That's not counting the first cam, the first set of pistons, rods, gaskets, etc.
Okay, it's definitely maybe possibly under 3000, but maybe not.
But it's still worth every penny.
P.S.- I actually had to buy 2 throw-out bearings cause I laid the first one down in the shop and was never able to find it again.
I NEED MORE TORQUE!
'03 Rubicon w/4.6: kb pistons, late 70's 4 weight crank, Mopar P4529228ab cam, 240 dur./.430 lift, barely polished aluminum head. First fire 11/14/08, eventual mechanical issues, rebuilt January '26.
George Dickel
Post by George Dickel »
Spent $1800 on the machine work and parts for the longblock. Built it myself so saved significantly there. I did the port/polish job and port-matched the intake also. If you toss in the cost of injectors and ignition parts, you can add about $500 to that. So roughly, $2300ish. Hard to tell since I replaced all but two parts on the whole Jeep :lol:
'98 Wrangler Sport, 4.6L Stroker
'04 Mustang GT, 4.6L with a few bolt-ons
420CoMaNcHe
Stroker Displacement: 242
Vehicle Year: 1987
Post by 420CoMaNcHe »
If I had money I'd drop a lot into my lil 4L lol
Rubicon06
Vehicle Year: 2002
Vehicle Model: TJ
Post by Rubicon06 »
I plan to spend $1,500 to $3,000 I looked at the Titans 4.6 for $2,4990 and Golan for $3,4990
trailbound79
Vehicle Model: TJ
Post by trailbound79 »
I just got 1000 mi. on mine and love it. I have $925 into it plus oil filter and coolant. They bored it 30 over did the valves and cam, With new timing chain and gears plus includes a 4.2 crank and rods they had for 200. Only had to go to mid grade to git rid of the ping.
TheZaZ
Learning to use the board
Post by TheZaZ »
whats costing you guys so much at the machine shop? What exactly are you having them do?
Just wondering...as my bill should be less then $350-400...
Hot Tank- $45
Bore .060- $90 for all six
Install cam bearings- $20
Deck Block- $85
Setup rings on KB pistons- $45
Guy at the maching shop said he has never had an issure with KB pistons but the rings have to be setup right or you will have issues...so for $45 Ill just let them do it.
Ill be assembling the motor myself....
Winners97TJ
Stroker Displacement: 4.7L - In Progress
Post by Winners97TJ »
Well, up to this point, I picked up my block I am going to stroker, a crank with some misc. parts that are un-needed, pistons, gasket kit, valve springs, retainers, locks, timing set, lifters, and cam for $1,128.79. My total BEFORE getting ANYTHING machined is $1553.79. I think I'll probably go with bigger valves (which will be an additional $200) and not sure if custom push rods will be needed. I'm sure I'll be looking somewhere around the $3-3500 mark. I should be able to recoup some of that cost from the unused parts that I got with the crank and my 4.0L that is in my Jeep now. Going to do a Transmission refresh while I've got it out as well. I HOPE I don't hit $4k, but the way it looks and "since I'm there, I might as well do it right," I think I may! :slobber: :slobber: OUCH.
But HEY! Just think of the Rooster tail this thing will be able to throw when I'm done! :hrhr: :hrhr: :hrhr: :rockout: :rockout: :rockout:
BDD
I think I'll order a "tab"
Vehicle Model: tj
Post by BDD »
Ive got 187 miles on my motor and happy as a pig in s#*t. Here are some rough numbers off the top of my head.
Kb944 $415
505 stage 1 cam,lifters $262
12 wt crank 20/30 $105
Machine shop $525
Balence $150
Engine pro double roller timing chain $90
Hesco crank spacer for dampner $35
Melling hv oil pump 75?
Arp rod bolts $50?
Gaskets $75?
Rings,bearings $200?
I havnt paid for those yet so im not sure on the price.
2000 intake-free
24 lb fms injectors 8-$60 used
Clean inj.$50
The block was not decked the head was cut .010,new stock valves,perf grind, stock valve springs
Stock exaust,throttle body for now.ran out of money,i need a wideband next and then ill search for some of the power im missing with exaust,bigger t-body and some tuning (98 tj obd2)
LilJayV10
Post by LilJayV10 »
Subscribing. I will be watching this thread. I am looking to stroke a 4.0. I built several different type of engines in my life but not one of these. I have been reading this forum on links for three hours now.
:cheers:
Welcome. You'll have no problem building a stroker if you've already built a few engines. Keep on researching and let it soak in.
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
Jeees, just passed $5,500 so much for my $2500 budget!
J.B.
gonridnu
Vehicle Year: 1989
Vehicle Model: XJ 2 door
Post by gonridnu »
:banana: A lot?
I obviously got free machine work but it wasn't cheap for the engine parts and associated install parts. $450 at HESCO alone for a water pump, TPS adapter, distributor gear, and crank bolt spacer. I traded some rocker arms for the KB pistons so that helped to the tune of $500. Still I gotta think I'm in this at least a couple thousand bucks and when coupled with the long arm kit, trans, and transfer case I know I could have bought a newer something or other that would be nowhere near as fun as the Jeep.......
Oh yeah, and i leveraged the house for 6 "fuel line repair kits" at $12 a piece cause I didn't order em online like I knew I should! :banana:
