Hey Jeepers,
Well my engine is in, but the mechanic is stumped by the serpentine belt routing. He's done lots of Jeeps, but he can't remember the correct path on mine. He's tried the dealer and other sources, but he says mine has eight pulleys to thread through/around and he wants to make sure it's right. Mine is a '94 XJ with the only external change being the '99-up intake and power steering. Does this change add a pulley to the stock seven? Can someone draw me a routing chart? HELP SKIPPER!!!!!
Thanks,
Todd
SERPENTINE BELT ROUTING???? HELP!!!
crustodd2
- Vehicle Year: 1994
sudo chop
Re: SERPENTINE BELT ROUTING???? HELP!!!
Serpentine belt routing can be kind of dynamic, especially when you start changing things.
I think we can help if you post a picture of your setup, otherwise just try to find a diagram that has your same pulley setup, either in a manual or online...
1998 XJ
4.6L Stroker FINISHED
92tank
- Stroker Displacement: 4.5
all you have to do is make sure the belt is on the pulleys right (ex grooves on grooved pulleys and smooth on smooth) and make sure the belt is more than 1/2 way around the pulleys.
This might help: http://autorepair.about.com/library/faqs/bl-453h.htm
The '99+ intake and PS pump combination does add a tensioner pulley. I removed the idler pulley so I have mine set up like this:
crustodd2
Hey Dino,
Thanks, that helped. Almost alive again
T~
T~
