ok, tell me this is a dumb idea, or show me how to make it
4.whoa
Vehicle Model: xj&mj
Re: ok, tell me this is a dumb idea, or show me how to make it
Post by 4.whoa »
Can't you swap in a 46re :huh: IIRC it's just a stronger version.
-Russ
All XJ 4.0L autos are AW4s. I think one of the 4 cylinders or V6 had some other transmission, but the 4.0L always had the AW4. The ZJs also had a AW4, but that was only early 93 models. I had one and the transmission was about the only thing that worked correctly.
As far as the 44A is concerned... well, I wouldn't touch a 44A to begin with )its the A part), but it will have no issue with a AW4.
4.whoa
Post by 4.whoa »
I read an article in MOPAR ACTION a while back, they have a project dakota. They swapped a 42re for a 46re.
4= # of fwd gears
2 or 6 = tq rating- don't remember what they mean.
R = rear output or drive
E = elec shift or control
I'm not sure if they bolt up to the same transfer cases or not (output shafts) but otherwise should be no sweat. ;)
-Russ
kowboydmac
Where's the "any" key?
Vehicle Model: GC ZJ
Post by kowboydmac »
4.whoa wrote:I read an article in MOPAR ACTION a while back, they have a project dakota. They swapped a 42re for a 46re.
4= # of fwd gears
Hmm sounds feasible... what would a 46re come out of? Ram?
kowboydmac
SilverXJ wrote:All XJ 4.0L autos are AW4s. I think one of the 4 cylinders or V6 had some other transmission, but the 4.0L always had the AW4. The ZJs also had a AW4, but that was only early 93 models. I had one and the transmission was about the only thing that worked correctly.
Yeah I've already went through a process of which axle to go with, there's a company called Mountain Valley Custom that makes a truss for the 44A as well as a new cover from BlueTorch Fab, that pretty much cures the weak link there. And the Spartan locker has some pretty good reviews.
kowboydmac
Wikipedia has a pretty good list of Auto trannies
"42RH
A renamed medium-duty A500. A998 with overdrive and hydraulic control.
[edit]
44RE
A renamed heavy-duty A500. A999 with overdrive and electrical control.
[edit]
46RH
A renamed A518. A727 with overdrive and hydraulic control.
Applications:
1994-1995 Dodge Ram 2500/3500 V8
1995 (Jeep Grand Cherokee 5.2)
[edit]
46RE
A renamed second-generation A518. A727 with overdrive and electrical control.
Applications:
1996 Dodge Dakota V8
1996-2002 Dodge Ram 1500/2500/3500 V8
1998-2000 Dodge Durango 5.9L V8 (4WD or 2WD)
1998 Jeep Grand Cherokee 5.9L V8 (4WD or 2WD)
[edit]
47RH
A renamed A618 and hydraulic control.
Applications:
1994-1995 Dodge Ram 2500/3500 Diesel/V10
[edit]
47RE
A renamed second-generation A618. A heavy-duty A727 with overdrive and electrical control.
Applications:
1996-2002 Dodge Ram 2500/3500 Diesel/V10
[edit]
48RE
The 48RE is an electronically-governed, four-speed heavy-duty overdrive automatic transmission, stronger than its predecessor, the 47-series.
Gear ratios:1 2 3 4 R
2.45 1.45 1.00 0.69 2.21
Applications:
2003-2004 Dodge Ram 2500/3500 ISB Diesel
2003-2004 Dodge Ram 2500/3500 HO ISB Diesel
2004-2007 Dodge Ram 2500/3500 600/610 Diesel
2004-2006 Dodge Ram SRT-10"
I'm slightly hesitant to use a chrysler transmission though because I've heard and gone through quite a few problems with them, but I know once they've been rebuilt and from what i hear, installing a shift kit, they run very well. Just looking for my cheapest most reliable option.
comanchemty
Vehicle Year: 1987
Vehicle Model: comanche
Post by comanchemty »
Back to your original post. I was wondering why you want to remote mount your turbo. The plumbing is much easier if it stays close to the motor.
kowboydmac
comanchemty wrote:Back to your original post. I was wondering why you want to remote mount your turbo. The plumbing is much easier if it stays close to the motor.
Well that was before I saw the boostwerks manifold; Till then I just figured that was the easiest way minus running the oil lines. I've never turbo'ed anything before. I have a ton to learn! lol
I just got a book from Jay K Miller to reference. Pretty informative for a newbie like me.
I noticed most new people don't think about the drivetrain when adding boost... guess I'm ahead of the game in that regard lol.
Users browsing this forum: Bing [Bot] and 0 guests
