New to building motors, but wanna try
xtremzj
Vehicle Model: ZJ
Post by xtremzj »
hello. n00b here. I currently have a modded 4.6 Golen stroker motor i bought and had them do some extra mods to it while it was there (port polish, blue print, bored out) And i love it! I spent a pretty penny buying it and now wanna try my hand of building one for myself (only way to learn right). Im a mechanic so i have basic knowlede and whatknot.
What i wanna do is build a 4.8-4.9 (i just want more power!) I thought about just supercharger the 4.6 but really just want to build it and put it in and keep the 4.6 as a spare.
Sooooooo where do i start, whats all the best stuff i can buy? Whats the average price are people paying to build these?
Be easy on me! :flame suit on:
here is a pic of the jeep
mikey_d_13
Where's the "any" key?
Re: New to building motors, but wanna try
Post by mikey_d_13 »
i just finished a 4.5 and its alot of fun building, especially if you dont need it right now..
as for the best parts and what you need..start with your formula and get a 4.0 block, get all the machine work and evrythin, and a 258 crank and maybe rods depending on ur plans
xtremzj
Vehicle Model: ZJ
Post by xtremzj »
Bump.
So I have the block, 4.2 crank and rods, stock head and cam.
What's the next step? Just bring everything to a machine shop? I know I need pistons (not sure which ones yet) but what else do I need?
I've done lots of reading and get mixed answers.
xtremzj wrote:So I have the block, 4.2 crank and rods, stock head and cam.
You said that you wanted a 4.8-4.9L displacement in your first post but that's only possible with a custom billet crank ground with a stroke of 3.98" or higher. You could, however, have the rod journals of your existing crank offset-ground 0.040" undersize to increase the stroke by 0.020" to 3.915". With +0.060" pistons you'd have a displacement of 4681cc and you could copy this recipe:
4.7L medium-buck stroker
Jeep 4.2L crank offset-ground to 3.915" stroke
Jeep 4.0L 6.125" rods
Keith-Black UEM-IC944-060 pistons
10.0:1 CR
CNC ported HO 1.91"/1.50" cylinder head
Mill block deck 0.018"
0.043" quench height
Flometrics F&B 68mm billet TB
Accel 26lb/hr injectors for '96-'04 engines
281hp @ 5000rpm, 337lbft @ 3700rpm
You'll need to buy the pistons first (with rings) and take them to the machine shop before they can rebore the cylinders. Naturally you'll also need a shopping list of other parts including main/rod/cam bearings, freeze plugs, oil pump, timing set, upper/lower gasket sets, cam/lifter kit, valve springs/retainers/keepers, roller rockers, oversize injectors, high-flow water pump, thicker radiator, and an auxiliary tranny cooler.
EVIL95XJ
Vehicle Year: 1995
Vehicle Model: cherokee
Post by EVIL95XJ »
you`ll be fine, i just built my stroker over the summer, first ever motor build, just got it dialed in recently and runs great, good luck
Ford 24# injectors - PM me
Users browsing this forum: Bing [Bot] and 5 guests
