4.5L Low Budget Build/Simple Stroker
ccpanel
Stroker Displacement: 275
Vehicle Year: 1950
Vehicle Make: chevy
Vehicle Model: truck
Re: 4.5L Low Budget Build/Simple Stroker
Post by ccpanel »
rradford9 wrote:Everything started a couple of weekends ago when I pulled the oil pan after hearing the an annoying "tick" get a lot worse! I found about 1/4 of the #4 piston in the bottom of the oil pan. The picture makes it look a lot worse than it ended up being. Amazingly there was no damage to the cylinder wall!
So I decided since I needed to replace the piston, might as well upgrade while we're in there. Plan is to go with a 4.5L Simple Stroker from Dino Saava's 4.0 performance site. I modified it a little bit b/c the 677cp pistons were hard to find.
Specs:
* Jeep 4.2L 3.895" stroke crank
* Jeep 4.2L 5.875" rods
* Sealed Power H802CP standard bore pistons (dished to 18cc's)
* 9.25:1 SCR
* 7.96:1 DCR
* Stock 4.0 camshaft
* Port & Polish cylinder head
* Mopar/Victor 0.043" head gasket
* 0.081" quench height
* stock injectors with stock 49psi FPR for '96 and later engines
* 247hp @ 4900rpm, 300lbft @ 3500rpm (thats what Dino's site says)
mine was #5 piston in my 258.
http://www.youtube.com/watch?v=O0U8zx1noNs
stroker is going to machine shop tomorrow.
tryin to figure out which piston will let me run pump 87/89 gas.
thinking of using the 2229 pistons from summit racing.
eastin82
Post by eastin82 »
did you try falcon on ebay for the pistons?
keepin the five alive!
WJ 2000
Vehicle Model: GC/WJ
Post by WJ 2000 »
Hey Man I'm thanking of doing the same rebuild on my 4.0 WJ 2000 , check out my thead
''stroke or not to stroke'' I need more info :cheers:
Thanks WJ 2000
ccpanel
Vehicle Year: 1950
Vehicle Make: chevy
Post by ccpanel »
WJ 2000 wrote:Hey Man I'm thanking of doing the same rebuild on my 4.0 WJ 2000 , check out my thead
Thanks WJ 2000
dont bother. its nice but the expense versus reward is minimal.
it was also a PITA getting my excellent machinist to get factory parts to conform to my blueprinting desires...
not starting a discussion thread here-PM me if you want details.
jk333
Vehicle Year: 1987
Post by jk333 »
Have you been running 87 octane consistently in the stroker since you installed it? And if so, how does it perform? any problems? (after the initial tank of mid-grade I mean) Thanks.
ccpanel
Vehicle Year: 1950
Vehicle Make: chevy
Post by ccpanel »
jk333 wrote:Have you been running 87 octane consistently in the stroker since you installed it? And if so, how does it perform? any problems? (after the initial tank of mid-grade I mean) Thanks.
i exclusivly run 91 octane. never would consider anything else. CA gas is junk so my 91 is your 50... PITA...
if i didnt mention already-my gains are not your gains as i am a Luddite and insist on running a 2100 carb. #50 jets currently
10:1 static and 8:1 dynamic with 1989 renix cam.
SO... yeah-i may have built a 300hp motor and choked the snot out of it by not max cam and FI...
I sitll like the motor and I loved building it.
I am slow so the time it took versus the reward I expected but didnt see meant a 4.0 would have been a good choice for me.
I also get 14mpg which is good considering my rig
rficken42
Vehicle Year: 1999
Post by rficken42 »
was anything done to the block during this build?
also if i am already and continuing to run high octane. would the block need to be decked?
ccpanel
Vehicle Year: 1950
Vehicle Make: chevy
Post by ccpanel »
rficken42 wrote:was anything done to the block during this build?
block was align honed and bores squared to deck.
it was also decked to obtain a "ZERO" deck height so my quench was the thickness of my headgasket.
rficken42
Vehicle Year: 1999
Post by rficken42 »
Your engine or rradfords99 ? I was asking about his engine.
bradtabor
Stroker Displacement: 4.2
Vehicle Year: 1989
Post by bradtabor »
Just curious because I am building going to build a stroker but what is the compression if you do not dish those pistons to 18?
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Vehicle Model: GCh 4.0
Post by darkcorp »
Hi!
How did you get 9.57:1 SCR / 8.28:1 DCR and 0.050" Quench on H802CP pistons (18cc dish)?
According to Stroker Compression Ratio Calculator you must have 9.83:1 SCR / 8.5:1 DCR at 0.050" Quench.
Users browsing this forum: Google [Bot] and 10 guests
