Also, I don't know if it was the 4.2L or 4.0L but one of the engines originally didn't come with the pin and spring to begin with. It was added later and there is an AERA bulletin on that being a fix for a knocking sound. And Jeep did switch to a retainer plate in the last years.dwg86 wrote:I have also heard that a hyd cam is ground to keep the cam in the block, but most engines have some sort of cam retainer. And engines that were not manufactured with a cam retainer, have some sort of after market retainer (SBC).
I have also heard that a flat tappet cam is ground to pull the cam back into the block. Then what would be pushing it forward? The oil pump?
I mocked the engine up yesterday(head on w/ old gasket, torqued down, solid lifters, rockers, engine mounts, etc) and couldn't find any issues. I left the timing chain off so I could just feel the cam and valve train with out any interference from the crank and pistons. With the head on, and engine mounts on, the cam still turned fine. With the valve train on I didn't find anything that indicates any binding. With the full valve train on initial torque to get the cam turning is 265-390 in lbs, depending if I started it when a valve was near the full open or not. Constant rotating torque is 159-160 in lbs, again depending if a valve is opening or not.
I also measure how far forward the cam can move with its the spring and pin setup. .105" and with the valve train out it didn't require much force to get it to. I don't see how that would hold the cam in the block with any real force against it. If the cam is bouncing back and forth it would certainly explain that knock sound that was always present.
