Engine Weight
Mr.Mopar
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: AMX
Engine Weight
Just wondering if anyone knows the weight of a complete 4.0? Specifically a 1996. Curious what a 4.2 weighs complete?
5-90
Re: Engine Weight
A "bare" 6-242 crate tips around 550-600#. Figure accessories are going to add 40-50# or so - call it 650# for a "heavy guesstimate."
The 6-258 should be somewhat similar - even though the bore is smaller (meaning less material to make the cylinder walls,) and it's an older casting that wasn't lightened. So, I'd figure the bare 6-258 crate to be up around 600-625#, with a similar figure for bolt-ons.
Either way, you're likely to end up in the range of 600-700#. Price of having a durable seven-main I6!
Mr.Mopar
- Vehicle Make: AMC
Re: Engine Weight
A 4.0 weighs about the same as an AMC V8? They weigh approximately 550 lbs.
BADASYJ
Re: Engine Weight
I really don't think those numbers are right, 550# seems a bit high. A 400 Mopar big block wieghs in at 330#. No way that the I6 weighs more then a Big Block. I can pick up and carry a bare 4.0 block myself.
Some body needs to weigh one.
Re: Engine Weight
IIRC the block weights about 250, the crank weights around 45, loaded head is 75, The cam is around 10, figure another 10 for the pushrods, lifters and rockers, 3 for the oil pump, and figure another 20 for pistons and rods. You are right around 410 with out oil pan, valve cover, water pump, timing set, timing cover, etc. I do know that the 4.7L V8 clocks in under the I6 weight.
BADASYJ
Re: Engine Weight
My bad, a bare mopar 400 B block weighs in at 225lbs. Aftermarket block weighs in around 330lbs. I think I'll weigh a bare 4.0 block tonight n git back with ya.
wacked
Re: Engine Weight
JEEP AND GM ENGINE WEIGHTS:
Their nominal estimated, accessory loaded weights are:
•2.8L V6, 365 lbs.
•2.5L I4, 340 lbs.
•4.0L I6, 515 lbs.
•Chevy 4.3L V6, 425 lbs.
•Chevy Small Block V8 (Gen. I & II), 550 lbs.
•Chevy Small Block V8 (Gen. III+), 470 lbs.
•Chevy Small Block V8 (LS1), 407 lbs.
•Buick 90 degree V6, 375 lbs.
•Buick 60 degree V6, 350 lbs.
INFO courtesy of Novak-Adapt
•2.8L V6, 365 lbs.
•2.5L I4, 340 lbs.
•4.0L I6, 515 lbs.
Mr.Mopar
- Vehicle Make: AMC
Re: Engine Weight
I guess the 4.0 is no light weight lol Not much of a weight savings from an AMC V8
Re: Engine Weight
Not trying to be argumentative, but if the bare block weighs 250# I must be stronger than I think. I picked up my bare block and set it in the back of my truck.SilverXJ wrote:IIRC the block weights about 250, the crank weights around 45, loaded head is 75, The cam is around 10, figure another 10 for the pushrods, lifters and rockers, 3 for the oil pump, and figure another 20 for pistons and rods. You are right around 410 with out oil pan, valve cover, water pump, timing set, timing cover, etc. I do know that the 4.7L V8 clocks in under the I6 weight.
Carl
Re: Engine Weight
The 258 (and older) blocks were a little heavier than a 4.0. Through about 1980 both intake and exhaust manifolds were cast iron and very heavy. I would estimate about 75-100lb more than a 4.0, including manifolds.
Re: Engine Weight
That is why I said IIRC. It might be IIRIdwg86 wrote:Not trying to be argumentative, but if the bare block weighs 250# I must be stronger than I think. I picked up my bare block and set it in the back of my truck.SilverXJ wrote:IIRC
Re: Engine Weight
I'm not a smart man...What is IIRC?
GoMopar440
Re: Engine Weight
IIRC = If I Remember Correctlydwg86 wrote:I'm not a smart man...What is IIRC?
Dont know what IIRI is though. I'll let Silver answer that one himself.
- amcinstaller
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: Engine Weight
incorrectly
Re: Engine Weight
Got it!amcinstaller wrote:incorrectly
Users browsing this forum: Amazon [Bot], Google [Bot], Semrush [Bot] and 3 guests
