muffler choice on a stroker?
H.M.X
Where's the "any" key?
Post by H.M.X »
so which muffler sounds the best on a stroker? do they sound any different than stock engines?
dan
Shark
Consistent
Consistent
Re: muffler choice on a stroker?
Post by Shark »
im partial to flowmaster but i dont have a stroker yet.
'95 XJ 4door 4.0 aw4 2" 31's
Post by John »
I just put a flowmaster super 44 on mine and really like it . Sized 2 1/2" nice exhaust note without drone or ricer fart can sound. They are a little louder than some but I like to hear the sound of the 4.6 under power.
aaronkeiser
Vehicle Year: 1991
Post by aaronkeiser »
Id go with a flowmaster as well, they have the delta flow series ones that are loud outside and quieter inside. They have a bunch of super ones which are the louder ones (loud doesn't usually mean bad). You could also check out the magnaflow ones, they look pretty good. I'm running a cherrybomb turbo muffler which I like a lot since I only paid 30$ at pep boys. when I do my exhaust right i'll get the Carsound High flow cat and flowmaster 40 deltaflow since I have a ragtop and I can hear EVERYTHING :shock:
Post by John »
The super 44 is with the Delta tech. I went with it to try and improve velocity through the system, we will see. Got to get under the rig with a IR thermo gun.
From their website:
Super 44's
Super 44 -NEW!- Two Chamber Mufflers
Flowmaster’s NEW Super 44™ muffler with its 4” x 9.75” x 13” all black finish case offers distinct advantages over our original 40 Series™ muffler. Using the technology seen in our larger Super 40™ mufflers, the Super 44™ delivers a rich deep tone, an improved flow path radius, optimum internal flow and sound control, all created with Flowmaster’s Delta Flow® technology. It is the most aggressive, deepest sounding, highest performing four inch case street muffler we’ve ever built!
Shark
Consistent
Consistent
Post by Shark »
so i guess its unanimous. flowmaster it is.
1bolt
Post by 1bolt »
My vote is for Flowmaster as well,, almost but not quite a V8 sound...
Simon
Post by John »
1bolt, when any of my 6's sound like a V8, I'll quit. Been building Inline 6's for about 40 years because I prefer them. Of cours I did check out a Offy 4cyl once, hot date but not to bring home to your mom.
Heck
Post by Heck »
My Magnaflow isn't much louder than stock, even though you could look straight through it. It has a great growl from about 4400 rpm on (which means I probably won't hear it 3 more times in my lifetime) but doesn't really sound like anything other than a loud stock muffler otherwise. Has great flow, though.
I NEED MORE TORQUE!
'03 Rubicon w/4.6: kb944 pistons, late 70's 4 weight crank, Mopar P4529228ab cam, 240 dur./.430 lift, barely polished head. First fire 11/14/08, no mechanical issues so far.
Post by John »
Heck, I run a magnaflow on my street legal 99 TJ and I agree they sound good. I went with the Flowmaster for the beast YJ because I can more easily build a tuned system with it and it has a much more authoritative bark throughout it's rpm range. I have driven the TJ coast to coast on a summer a few years ago. The flowmaster might have gotten old by the time I got across Kansas, but for what the YJ is built for, I find it perfect. But yes, the magnaflows sound nice when you light them up.
I have a Gibson on my XJ. Its ok. Slightly louder than stock and it sounds decent. However, I have found that they don't flow much better than stock. I'm looking for something else. Don't want to go the flow master route though.
Jeep-Power
Stroker Displacement: 4.3
Vehicle Year: 1984
Vehicle Make: AMC/Jeep
Vehicle Model: CJ-7
Post by Jeep-Power »
Whatever you get-- be sure it, and the entire system, is 2.5"-- I'm running a stainless Dynamax straight through job (ebay special $20!)-- it sounds GREAT!
I'm gonna initially use my current Borla w/Magnaflow cat setup on my stroker. It's 2 1/4" the whole way until the 2" tailpipe section. I love the quality sound: no drone and quiet off throttle, but wicked when you get on it. I might find that I'll want to go with a bigger downpipe and back, but until then. . .
4point6
I think I'll order a "tab"
Post by 4point6 »
TallPeter - where did you get the 2.5" all the way through? Is it custom, or is there a bolt up system out there? Everything I could find was 2" or 2.25".
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
'67 Mustang Fastback (project)
My Gibson is 2.5"
