6.125 rod length
1.948 1/2 of stroke length
1.353 KB piston pin offset
________________________
= 9.426 total piston height
9.453 average deck height
- 9.426 total piston height
_________________________
= .027 piston down in the hole before decking
Trying to wrap my head around it...
- Busey
jbxx
- Stroker Displacement: $.6 mistake?
- Vehicle Year: 1986
- Vehicle Model: CJ7
Re: Trying to wrap my head around it...
Worked for me
Jeep Strokers
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
Static/Dynamic Compression Ratio Calculator
http://www.jeepstrokers.com/calculator
Your Data:
Cylinders: Cylinders 6
Bore: inches 3.905
Stroke: inches 3.895
Combustion Chamber: cc 58
Deck Clearance: inches 0.00
Gasket Thickness: inches .051
Gasket Bore: inches 4
Dome/Dish/Valve Relief: cc 21
Piston Ring Height: inches
Piston to Bore Clearance: inches
Connecting Rod Length: inches 6.123
Cam Intake Duration: degrees
Cam Lobe Separation Angle: degrees
Advance or Retard: degrees
Your Cam Selection: none
Manufacturer:
Model Number:
Your Calculated Results:
Cubic Inches: 279.89
Liters: 4.59
Static Compression Ratio: :1 9.54
Dynamic Compression Ratio: :1 1
Quench: .051
Intake Valve Closing Angle: -180
Jeep Strokers
Your Data:
Bore: inches 3.905
Manufacturer:
Model Number:
Liters: 4.59
Quench: .051
casual
- BANNED
- Vehicle Model: xj
I was using the other calculator....this one
http://www.editgrid.com/user/brewmenn/stroker
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
