turbocharged
Spliffotticle
- Stroker Displacement: 4.59L
- Vehicle Model: WJ
turbocharged
I am interested in knowing who is running boost and what your DCR is. Please give useful specs if you are going to spec drop. We like dimensions in our tech forum, not brand names.
bored, check. stroked, check. turbocharged, check. functional, information unavailable
Jeep's Jake
Re: turbocharged
Well I suppose I can try to start this off. It's nothing too crazy, but it still gets up and moves...
Stock 4.0
8 PSI with an M90
Mild head/Intake work
MP head gasket
Comp 68-232-4
The calculator on this site puts me at roughly 7.7:1 DCR before boost.
Stock 4.0
8 PSI with an M90
MP head gasket
Comp 68-232-4
Spliffotticle
- Vehicle Model: WJ
Re: turbocharged
I am really staring to worry that my 9.4-1 dcr is an obstacle. I have no low end what so ever but I'm not sure I'm all put together right. I will probably need to bone up on cam advancement and the CPS relation:'( I guess I should have started a thread about CPS and cam advancement....
bore: 3.935"
stroke: 3.895"
combustion chamber: 58cc
deck clearance:.0085"(decked .013")
gasket:.051"
gasket bore: 4"
dish: 13cc
connecting rod length: 5.875"
comp cam 68-115-4 advanced 4*
duration 240*
angle of separation: 108*
displacement: 284.21ci (4.66l)
SCR: 10.33
DCR: 9.4
quench.05949
IVC angle: 44*
turbocharged running 91 (obviously not building boost while I'm falling on my face)
bore: 3.935"
stroke: 3.895"
gasket:.051"
gasket bore: 4"
dish: 13cc
duration 240*
SCR: 10.33
DCR: 9.4
quench.05949
IVC angle: 44*
Spliffotticle
- Vehicle Model: WJ
Re: turbocharged
er... I mean CMPSpliffotticle wrote:I am really staring to worry that my 9.4-1 dcr is an obstacle. I have no low end what so ever but I'm not sure I'm all put together right. I will probably need to bone up on cam advancement and the CPS relation:'( I guess I should have started a thread about CPS and cam advancement....
shawnxj
- I love this board
Re: turbocharged
how much boost are you running at that high of a compression? everybody i've talked to about my build said at 9.55 scr i'm at the max to be able to run even 10 lbs of boost
Spliffotticle
- Vehicle Model: WJ
Re: turbocharged
I haven't even bothered looking @ boost level yet because I am falling on my face before boost comes around.... I set my intercooler up with a BOV on it directly as well as an adjustable pop-off valve set @ 10psi... until I get to the using boost phase.
Jeep's Jake
Re: turbocharged
Ill be interested to see what kind of boost that will tolerate when you get it going. Not to repeat what you already know, but I agree with what was said in your cam post - that the TPS and the large TB are your low end issue. What kind of MAP sensor setup are you running?
As a side note on boost, my only detonation occurs at part throttle, lugging, between 0 and 2 PSI in 5th gear. High RPMs and/or full pressure work great without pulling timing. The high DCR may limit your total amount of boost, but should make for a great all around engine with some huge pickup even at 5 pounds of boost.
Spliffotticle
- Vehicle Model: WJ
Re: turbocharged
Stock with a check valve on it. I heard the computer doesn't like to find out it has pressure & not vacuum.Jeep's Jake wrote: What kind of MAP sensor setup are you running?
Jeep's Jake
Re: turbocharged
Yea I hate to say it but In my experience the stock sensor does nothing but cause problems. Some people buy a boost referenced FPR to make the stock MAP work... supposedly. Never tried it, but for the money (and the sake of your high compression engine) I think you'd be better off doing a GM 2 bar sensor conversion or spend the extra $$$ and get an FTC-1. The timing control is invaluable and the fuel curve can be properly adjusted for injector size, load, boost, etc. Their customer support rocks too.
What is everyone else running as far as engine management goes? Anyone make the stock sensor work without stumbling, lean conditions or above all - that stupid CEL?
4.whoa
- Vehicle Model: xj&mj
Re: turbocharged
That's not gonna work right @all. You really need the 2 bar. Even if the check valve let's it run right n/a (won't if its sealing tightly) when the boost comes in without referenced fuel alterations..... Well its not gonna be good.
-Russ
Spliffotticle
- Vehicle Model: WJ
Re: turbocharged
This seems very vague. Can you go into further detail with some references even? Personally, when I minister, I like to give scripture references to back up what I say. On the fly... kinda hard. For a lesson, however, I try to prepare not only the theorem, but also the basis for my postulation, which is what I cite. You seem to have some useful info but you only hinted at the revelation of it. Does somebody know more than they are letting on??? ALSO! I was thinking about plumbing the MAP to the inlet of the turbo so it will always read vacuum (as well as everything else vac operated besides brakes) ... . . . You ever heard of anything like this?4.whoa wrote:That's not gonna work right @all. You really need the 2 bar. Even if the check valve let's it run right n/a (won't if its sealing tightly) when the boost comes in without referenced fuel alterations..... Well its not gonna be good.
Re: turbocharged
You will need a piggy back, a 2 bar MAP sensor and larger injectors. The stock PCM doesn't know what to do with boost nor can the stock MAP sensor read it. And if you don't already have one you will want a wide band O2 sensor setup. Bryson on NAXJA had good luck using an AEM unit for the piggy back. Also, as others have said that throttle body is too large and you need to fix the TPS.
montelibre
Re: turbocharged
Perhapas my last post can learn what not to do...
Re: turbocharged
Yes. http://www.jeepstrokers.com/forum/viewt ... f=5&t=2474montelibre wrote:Perhapas my last post can learn what not to do...
What happens when you try to run boost using larger injectors on an otherwise stock fuel system.
4.whoa
Re: turbocharged
Well, i wasn't meaning to preach.Spliffotticle wrote:This seems very vague. Can you go into further detail with some references even? Personally, when I minister, I like to give scripture references to back up what I say. On the fly... kinda hard. For a lesson, however, I try to prepare not only the theorem, but also the basis for my postulation, which is what I cite. You seem to have some useful info but you only hinted at the revelation of it. Does somebody know more than they are letting on??? ALSO! I was thinking about plumbing the MAP to the inlet of the turbo so it will always read vacuum (as well as everything else vac operated besides brakes) ... . . . You ever heard of anything like this?4.whoa wrote:That's not gonna work right @all. You really need the 2 bar. Even if the check valve let's it run right n/a (won't if its sealing tightly) when the boost comes in without referenced fuel alterations..... Well its not gonna be good.
Sorry, i don't remember exactly where I read what,so i can't say with certianty "this told me" or "who said what".
-Russ
