Conversion
Racin#81
- Stroker Displacement: 292
- Vehicle Year: 1994
Conversion
I have a newer jeep with the coils over the spark plugs. i was wondering what u have to do to use a distribtor? what would i have to change?
Re: Conversion
PCM, wiring harness, cam sensor, and possibly the oil sensor. Source parts from a 99. Why do you want to change?
lafrad
Re: Conversion
dude, coil over plug is WAY better than the distributor setup... why would you want to change? the distributor ONLY shares the spark from a single coil, with 6 cyl. it does NOT do anything for timing.... 3 coils for 6 plugs is way better than 1 coil for 6 plugs...
Racin#81
Re: Conversion
thanks guys i didnt know what way was best but i will stick to the coil set up
