need help
apsracing
Vehicle Year: 1995
Vehicle Model: yj
need help
Post by apsracing »
I am building my first jeep engine and need some help. i would like to know if the parts will work
crank is a 4.2 crank from SCAT
i want to use 4.2l rods from 505performance and IC 944-020 pistons.
i don't plan on zero decking the block i know that will increase the quench.
Re: need help
With the IC 944s you need the 4.0L rods, not the 4.2L rods.
apsracing
Vehicle Year: 1995
Vehicle Model: yj
Re: need help
Post by apsracing »
yes thats what i meant to type
http://www.shop.505performance.com/prod ... egoryId=29
and with them i shouldn't have an interference issue
dragginwagon406
Re: need help
Post by dragginwagon406 »
Just be careful with the corners of the small end balance pad to the inside of the piston.
