Muad'Dib 4.7L stroker build
- Muad'Dib
When i measure the pushrods, do i do it on all 12? Or is 1 ok? Do i need to make sure the Engine is at a specific position?
I would at least do the front and the rear cylinders. bring the piston up to TDC on the compression stroke. Insert pushrod, put on rocker, measure. The piston needs to be on TDC of the compression stroke so that the intake and exhaust lifters are on the base circle of the cam.
- Muad'Dib
So do both intake and exhaust on #1 and #6... got it!SilverXJ wrote:I would at least do the front and the rear cylinders. bring the piston up to TDC on the compression stroke. Insert pushrod, put on rocker, measure. The piston needs to be on TDC of the compression stroke so that the intake and exhaust lifters are on the base circle of the cam.
Thanks for answering all my noobish questions
- Muad'Dib
Is there any pro/con to getting the right length pushrods compared to just shimming the rockers?
Also, can i replace the rocker bolts with new grade 8 hardware or similar... or are these special duty?
Getting the push rod length correct vs. shimming the rocker arm can effect valve train geometry. Push rod length won't as it just changes preload on these engines. Shimming it will. I don't think it is as critical as some engine on these though, but you should check it. As far as the shim itself, it should be hardened and you won't find the correct thickness at a hardware store.
I am unsure of the stock rocket arm bolts, but you should be fine with grade 8. Harland sharp roller rocker uses off the shelf socket cap screws.
- Muad'Dib
Thanks man for all your help it has really been a life saver!
Measured pushrods today. Both intake and exhaust on #1 and #6 TDC.
Each were almost the exact same @ 13.25 turns.
So 13.25 x. 050 = .6625
.6625 + 8.8 = 9.4625 Measured Length
9.4625 + .030 = 9.4925 Length with desired preload (.030)
Hows that look?
Hows that look?
Looks good to me.
- Muad'Dib
Turns out Smith Bros Pushrods is right here in town. Drove over earlier and told them what i needed. Came home with nice new pushrods. They have tons in stock and ready to ship also! 5/16 Diameter, .083 wall. More specs and pics to come after work.
- seanyb505
- Stroker Displacement: 280ci
It always feels good to find exactly what you're looking for locally.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
Thats nice. No waiting.
- Muad'Dib
Pushrods are 5/16 Diameter, .083 Wall @ 9.5". This increased my Preload by .0075 totalling .0375. Still looking good IMO.
I also updated the main post with a updated parts list and price totals.
PICS:
PICS:
That preload is fine. It should work well.
- Muad'Dib
- IH 392
I was over there in Bend yesterday, I should have stopped by and offered some constructive criticism!
- Muad'Dib
Why yes .. yes you should have ....
Then you could have laughed at all my tools laying all over my garage and wonder how i find anything lol
