anyone think about the trany?
sour dalton
Vehicle Model: cherokee
Post by sour dalton »
hey all, new to the site...... considering building a stroker for my cherokee but a little concerned about how much torque the auto trans can handle in it's stock form...is there aftermarket support to beef it up or is there a swap i should be considering? :huh:
Re: anyone think about the trany?
These AW4's came in Supra's and can handle alot of power. No need to worry about it.
montelibre
Post by montelibre »
I don't know how much torqe can it transmit, I had it runing in my Stroker with Supercharger (about two weeks, until that the engine broke) and not notice anything strange or more slippage in the converter.
The AW4 is pretty stout. Put a cooler on it and it will last a lot longer. There are a few mods you can do. You can increase the shift pressure (I think that is what it is). You will have to search on that. It entails adding washers to stiffen some springs. I have not tried it myself. The PCM also have certain modifications you can do. You can have torque control and something else removed which will give you firmer shifts. That is just in the PCM, not the TCM. I had that done, but the company that did it for me isn't doing it anymore. But even in stock form it will hold up to a stroker.
92tank
Stroker Displacement: 4.5
Post by 92tank »
mine got 271,000 miles on it, about 20,000 with the stroker, and still does perfect. i have even pulled a few other cherokees home on a trailor with no problem
yuppiexj
Post by yuppiexj »
The current transmission in my Cherokee was pulled out from under my friends porch after sitting for 3 years.
The only reason I replaced it was, I damaged the front pump when swapping an engine. (it was whining and grinding itself apart, but still worked fine)
Fast forward 2 years and 35K miles it still works fine with 20 year old fluid.
TL:DR
An AW4 will still work with 20 year old fluid after sitting under a porch for 3 years
racing89
Stroker Displacement: 306 ci
Vehicle Model: comanche
Post by racing89 »
Good for 400+ H.P.. Dont know why anyone would consider a "swap" or upgrades to this apparently, indestructable transmission. Although line pressure can be easily "tweeked" with a cable adjustment(tighter is better). On a pure race application, cable can be pulled all the way out and "tied up", causing the firmist shifts at any throttle position. Hold on!
Freakin A Scrib
Post by Freakin A Scrib »
racing89 wrote:Good for 400+ H.P.. Dont know why anyone would consider a "swap" or upgrades to this apparently, indestructable transmission. Although line pressure can be easily "tweeked" with a cable adjustment(tighter is better). On a pure race application, cable can be pulled all the way out and "tied up", causing the firmist shifts at any throttle position. Hold on!
Is this the cable that runs to the throttle body?
sour dalton
thanks all!!! this was really helpfull !!! i'm not gonna worry about it then :rockout:
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Post by jeepman »
Here is something interesting...
I am thinking of ordering there rebuild kit or a completely rebuilt AW4 from them...
http://www.importperformancetrans.com/c ... -36-1.html
