engine mounts
Carl
engine mounts
Post by Carl »
Anyone know of a source for engine mounts to swap a 2000+ WJ/TJ 4.0 into a CJ or similar vehicle that was originally 258 powered?
Jeep-Power
Stroker Displacement: 4.3
Vehicle Year: 1984
Vehicle Make: AMC/Jeep
Vehicle Model: CJ-7
Re: engine mounts
Post by Jeep-Power »
did you ever get the mounts figured out?
Carl
Re: engine mounts
Post by Carl »
I have given up on finding any mounts that "bolt up." My options seem to be:
1. Use older HO engine. Mounts becomes trivial.
2. Fab custom engine brackets that work with old style 258 engine mounts.
3. Weld brackets to frame to allow use of newer type mount.
I have engines from 94YJ and 03TJ to choose from. I think I will go with option #1 to get my truck back on the road, then pursue #2 at my leisure.
92tank
Stroker Displacement: 4.5
Re: engine mounts
Post by 92tank »
what about the 91-95 yj wrangler mounts, the front part of the frames should be close enough to make them work
Tinga
Vehicle Year: 2002
Vehicle Model: TJ
Re: engine mounts
Post by Tinga »
You might try giving Brown Dog a call. They might be able to fab up some if you give them some measurements.
