Distributor off one tooth?
foggybottombob
Where's the "any" key?
Post by foggybottombob »
I recently had a 4.6L stroker built and the guy who put the distributor back on was not sure about the indexing. The engine runs but it seems very low on power for an over 10:1 static compression ratio. If the distributor is off one tooth will the engine even run? I need to get out there and check the timing with a light I suppose.
Re: Distributor off one tooth?
It will run but not well at all. Just try re-indexing it.. its not that hard and doesnt take to long.
foggybottombob
Now that I think about it, when I floored it to pass once I got several engine misses. It had the feel of an electrical problem. Does that sound like a possible disty indexing problem?
yuppiexj
Post by yuppiexj »
Yes
racing89
Stroker Displacement: 306 ci
Vehicle Model: comanche
Post by racing89 »
will run retarded 1 tooth and will suck.
foggybottombob
I just checked the timing and it looks to me like it is 6 marks above 0. I believe that is 12 degrees BTDC. This is at idle speed. I can't find a timing spec for a 91 4.0 anywhere. But I am thinking this may be too advanced.
foggybottombob
I had someone with a scanner check that the cam position sensor was in sync with the Crank position sensor and they are so I don't have a disty indexing problem.
tequila mike
Learning to use the board
Stroker Displacement: 4.6?
Vehicle Year: 1991
Vehicle Make: heep
Post by tequila mike »
If this is still alive.
FYI
I had to cut one fork of the distributor tab off to rotate it about a degree.
Now runs like a bat out of hell.
M
