Cam Specs
doc65
Where's the "any" key?
Vehicle Model: ZJ
Cam Specs
Post by doc65 »
So the compression calc only has the specs for the Renix & 99-2004 under the OEM, does anyone have them for the middle, specifically a 1996?
Re: Cam Specs
I believe that the '96-'06 cams are all the same grind, the early cams can be put in the late block but the late (thrust plate) cams don't work in the early blocks.
Re: Cam Specs
IH 392 wrote:I believe that the '96-'06 cams are all the same grind
AFAIK they all have the same profile but the '99+ cams are retained in the block by a thrust plate.
The Renix and '91-'95 HO cam are the same, but I suspect that the HO versions might have been installed at a higher intake centerline angle (later opening/closing intake valve) i.e retarded to prevent the engines from detonating 'cause the knock sensor was deleted.
Re: Cam Specs
96-98 have different cams that have a slightly longer exhaust duration. 87-95 cams have identical intake&exhaust durations and a slightly larger lift than the 96+
