acts like iut has a rev limiter at 4000 rpm
dewjeep
Vehicle Year: 1991
Vehicle Model: cherokee
Post by dewjeep »
i built a 4.6l stroker in the spring ran great till about a month ago.. it is acting like it has a rev limiter at 4,000 rpms will drop to 3,000 rpms and then back up to 4 but only des it driving or if i take it up slow in neutral. i have changed computer with a spare stock one, tps new, map new, o2 new, temp senser new, and crank senser is new.. lost on what else it can be... i am running a custom ground 440 lift rv cam, 30 over pistons, its a short rod stroker, 24lbs venom injectors, dynomax header and exhaust, excel coil, 8mm msd wires, and bosh platnium plus plugs... if you have any thoughts please let me know thanks..
p.s motor has tons of power till 4000 rpms till it acts like it has a low rev limiter.....
Missourian
Re: acts like iut has a rev limiter at 4000 rpm
Post by Missourian »
It may be in your muffler or exhaust system... something may have changed resulting in increased back pressure.
I have a 4.6L STOKER in my 2000 Jeep Wrangler with 4.5" lift on 35" BFG MT and 4.56:1 gears.
Check out Metro Crawlers Image
Post by dwg86 »
Distributor indexing?
herbiehind
Vehicle Year: 1999
Post by herbiehind »
fuel starvation?
Have you checked your fuel pressure? Last two times I had a symptom like this the pump was failing. Hit 3500 RPM and it was like it had a limiter. You may have to check it while driving as well because it didn't do it stationary when I had the problem.
dewjeep
Vehicle Year: 1991
Post by dewjeep »
i have just replaced the fuel pump because it died forgot to write that on the list of things replaced and did a new fuel filter at the same time
What is your fuel pressure like? You will have to check it while driving.
cameraman7d
Post by cameraman7d »
could be a cam going bad mine started doing that then would die... when it idled down.... good luck... ended up mine ate the #2 exhaust lifter...
dewjeep
Vehicle Year: 1991
Post by dewjeep »
i would hope the cam isnt bad motor is just broke in only has 4000 miles on it so far
dewjeep
Vehicle Year: 1991
Post by dewjeep »
will have to check fuel pressure yet dont have a fuel pressure tester and only get a couple days at a time home
cameraman7d
cameraman7d wrote:could be a cam going bad mine started doing that then would die... when it idled down.... good luck... ended up mine ate the #2 exhaust lifter...
also by the time this happened i had just hit 5500 miles on my motor... was a crane cam...
dewjeep
Vehicle Year: 1991
Post by dewjeep »
fuel preasure is staying at 41 p.s.i. from idle till it hits 4000 rpm
What year and what Jeep?
dewjeep
Vehicle Year: 1991
Post by dewjeep »
1991 jeep cherokee sport 2dr 5 speed
Missourian
Do you still have a catalytic converter on your XJ? :idea:
