Source for offset woodruff keys to tweek the cam timing
- Vehicle Year: 1987
I want to try advancing the stock cam a few degrees to boost the low end torque and DCR. I have been looking for offset 3/16 woodruff keys for this purpose, but can't seem to find them. Can anyone recommend a source for offset cam keys?
Re: Source for offset woodruff keys to tweek the cam timing
I don't know about the offset keys but my cloyes double roller timing chain set had a crank gear that was cut for 0 4 adv and 4 ret so you could choose a little timing differences.
I realize this drive set has that option, but this is a mild 4.6L and I will run the stock cam. I am looking for a less expensive option for now.
Drill the hole in the cam gear for the cam dowel larger and get a set of offset bushings.
Mopar/Direct Connection did have them for small blocks. pn P4286500. 3/16" x 3/4". These may be out of production. A google search on the pn may locate some.
Mr Gasket has them avail individually in both short 3/4" and long 1-3/8" lengths.
985G= 2 deg offset, long
987G= 2 deg offset, short
988G= 4 deg off set, short
http://www.summitracing.com/search/Bran ... toview=SKU
I haven't verified which length the Jeep uses!!....
Walt K
Eastern Pa
Eastern Pa
Thanks Walt.
The Jeep I6 uses the Chevy "short" woodruff (3/16" x 3/4"), as opposed to the Chevy long, which is 3/16" x 1 3/8".
- IH 392
It's been many years now but we did this insome of the 258's we ran in the early '80s, and we did use the "chevy" key.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 1 guest
