Another great fuel injector list
Retlaw01XJ
Vehicle Year: 2001
Post by Retlaw01XJ »
Stumbled on this great listing of injectors... Over 90 injectors listed with pics and specs! Primarily late model EV-6 style.
http://www.scribd.com/doc/63315218/List-Fuel-Injectors
..... wish I knew where this comes from, as the prices are around $10 an injector!
Most of the data matches Stan Weiss' info here:
http://users.erols.com/srweiss/tableifc.htm
Also found some actual flow data on the witchhunter site, including specs on the original Jeep 4.0 Chrysler/Siemens 04854181
http://www.witchhunter.com/injectordata1.php4
Witchhunter shows a flow of 225cc at a pressure of 3bar (43.5psi) for the stock injector.
Flow data for the Neon Bosch 0.280.155.784 is on this site:
http://www.fuelinjector.citymaker.com/F ... Rates.html
Rate here is shown as 223.9cc at 3bar, approx 21.3 lb
The Neon injector supposedly outflows the stock 4.0 jeep injector, but this data doesn't confirm this!
.....Sure wish there wasn't so much variation in test data between sites. Makes the choice difficult when we're dealing with such a tight range. :doh:
Target for a mild stroker appears to be in the range of 225cc to 240cc (at 3bar). Actual flow will be higher with our 49psi systems.
I'm most likely going with the Neon injector #4669938 /Bosch 0.280.155.784 for a mild increase. The Ford 4L3E appears to be the same injector.
If the local junkyard doesn't have any, I may get NEW replacements made by Standard and Motorcraft for $25 each.
Has anyone found other actual flow data for the stock or Neon injectors?
Walt K
Eastern Pa
Retlaw01XJ
Vehicle Year: 2001
Re: Another great fuel injector list
Another injector list, Thanks to Silver:
http://www.surplustraders.net/specs/yb464.php
Walt K
Eastern Pa
