new to the forum
boomerjeep
Vehicle Year: 2002
new to the forum
Post by boomerjeep »
as the title says im new to the forum and im in need of some help. i am getting ready to pull my engine and have decided to go ahead with my idea of building a stroker, my issue is that im looking for a parts list of everything i will need. im sorry if there is already one on here, i havent found it yet. any help you guys can give me would be greatly appreciated.
Re: new to the forum
Best to read the FAQ's and the posts in the "Projects" section to get started.
boomerjeep wrote:as the title says im new to the forum and im in need of some help. i am getting ready to pull my engine and have decided to go ahead with my idea of building a stroker, my issue is that im looking for a parts list of everything i will need. im sorry if there is already one on here, i havent found it yet. any help you guys can give me would be greatly appreciated.
What do you have now and how much do you have to spend on your stroker project? What type of use will the stroker be subjected to?
If you can answer those questions we can advise you on which parts to get and where to get them from.
Retlaw01XJ
Vehicle Year: 2001
Post by Retlaw01XJ »
This short list sums up 99.5% of what you'll need:
Crankshaft
Pistons
Bigger fuel injectors
Engine kit from a supplier like Falcon Global or Northern auto parts
There would be additional options such as a performance cam, valves/springs, roller timing chains, ARP rod bolts, etc.
Walt K
Eastern Pa
boomerjeep
Vehicle Year: 2002
i have a stock 4.0 jeep right now. ive got roughly 2500 to spend. i called a machine shop here in el paso yesterday and they quoted me 460 to bore the block, 3 degree valve job, decking if needed, balancing crank, shot peening rods and pressing the wrist pins and cam bearings. my jeep is mainly used for rock crawling and trail runs.
boomerjeep wrote:i have a stock 4.0 jeep right now. ive got roughly 2500 to spend. i called a machine shop here in el paso yesterday and they quoted me 460 to bore the block, 3 degree valve job, decking if needed, balancing crank, shot peening rods and pressing the wrist pins and cam bearings. my jeep is mainly used for rock crawling and trail runs.
Then this stroker recipe should be within your budget if you're doing the engine teardown/rebuild yourself:
4.6L low-buck stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Keith Black IC944-030 pistons
9.6:1 CR
Mill block deck 0.020"
0.050" quench height
Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors with stock 49psi FPR for '96 and later engines
What year is your Jeep?
Start looking for a 258 crankshaft in ebay to get the ball rolling.
boomerjeep
Vehicle Year: 2002
i have an 02 sahara. i really appreciate your help
Summit Racing is the best place to source most of the parts.
I'll put up a parts list in a separate post so others can use it as a reference.
boomerjeep
Vehicle Year: 2002
that would be a huge help! thank you very much.
boomerjeep wrote:that would be a huge help! thank you very much.
Here ya go:
http://www.jeepstrokers.com/forum/viewt ... =15&t=3030
boomerjeep
Vehicle Year: 2002
Yup. Good choice.
Cheromaniac wrote:Yup. Good choice.
Wait.. what? The springs retainers and locks won't work.
boomerjeep
Vehicle Year: 2002
so i would be better off just getting the cam and lifters?
yes
