new to the forum
Re: new to the forum
SilverXJ wrote:
Cheromaniac wrote:Yup. Good choice.
Wait.. what? The springs retainers and locks won't work.
Oops. Here's the correct link for the cam/lifter kit:
http://www.summitracing.com/parts/CCA-CL68-231-4/
and you'll need the following valve springs/retainers/keepers:
http://www.summitracing.com/parts/DCC-5249464/
http://www.summitracing.com/parts/DCC-4452032/
http://www.summitracing.com/parts/DCC-4529218/
Timing set:
http://www.summitracing.com/parts/CLO-9-3127/
Cam bolt/spring/pin & washer required to fit timing set:
http://www.hescosc.com/shop.asp?action= ... 343&catId=
http://www.hescosc.com/shop.asp?action= ... 344&catId=
boomerjeep
Vehicle Year: 2002
Post by boomerjeep »
thank you!
boomerjeep
Vehicle Year: 2002
i found a 258 crank online but when i asked if it was a 4cw or 12cw the guy didnt know. what do i tell him to look for?
boomerjeep wrote:i found a 258 crank online but when i asked if it was a 4cw or 12cw the guy didnt know. what do i tell him to look for?
The red arrows in these pics:
604rail_king
Vehicle Year: 1995
Post by 604rail_king »
Or ask for the stamping # off the crank and compare it to the list in the FAQ
boomerjeep
Vehicle Year: 2002
i have seen that everyone is partial to a specific head on here and i was wondering where to find a HO head? what years have them and can i take one off a cherokee and use it on my 02 tj?
boomerjeep
Vehicle Year: 2002
i have found 3 cranks all from 79-88 engines. is this the best cranks to get?
boomerjeep wrote:i have seen that everyone is partial to a specific head on here and i was wondering where to find a HO head? what years have them and can i take one off a cherokee and use it on my 02 tj?
Your existing '02 head will do fine so keep it. Just ask the machine shop to magnaflux it for cracks and check it for flatness. You could also ask them to do a 3-angle valve grind to improve airflow at low valve lifts (good for torque). If you're confident at porting a head yourself and you're handy with a die grinder, go for it. Otherwise either leave it to a professional or skip it altogether.
boomerjeep wrote:i have found 3 cranks all from 79-88 engines. is this the best cranks to get?
Any 258 crank from '72-'90 will do fine. Some prefer the '87-'90 short nose crank but it's hard to find one.
Make sure the head is a TUPY before doing anything to it.
boomerjeep
Vehicle Year: 2002
TUPY?
Newer 0331 heads with improved castings had TUPY stamped on the top between the no.3 and no.4 exhaust valve springs. These heads don't seem to have the cracking problems that are prevalent in '00-'01 heads.
Retlaw01XJ
Vehicle Year: 2001
Post by Retlaw01XJ »
More info on the good (2002-up) vs bad 0331 heads here:
http://www.jeepstrokers.com/forum/viewt ... 0&start=75
Walt K
Eastern Pa
boomerjeep
Vehicle Year: 2002
oh gotcha, thanks a lot. i really appreciate all the help and advice!
Users browsing this forum: Amazon [Bot], Bing [Bot], Semrush [Bot] and 2 guests
