Help with 4.6 stroker rebuild after failed cam gear
Re: Help with 4.6 stroker rebuild after failed cam gear
Post by dwg86 »
Did you degree your cam?
kkchevy3
I think I'll order a "tab"
Vehicle Year: 1991
Post by kkchevy3 »
Cam was put in straight up dot to dot. im using ngk bkr6e. distributor is in there but i had to cut the ears off cause it was about 1/8" off. 24* mustang injectors. i have an afe but the o2 sensor is bad and i need to get a new one. Stock map right now. pings under slight load. under 80% throttle for sure. stock map.
If you didn't degree the cam in it could be off... especially with the double roller sets.
kkchevy3
Vehicle Year: 1991
Post by kkchevy3 »
using a single roller setup
kkchevy3
Vehicle Year: 1991
Post by kkchevy3 »
the motor seems to ping in like 3rd or 4th light throttle up a hill. I guess there's really not much i can do at this point externally right?
CobraMarty
Post by CobraMarty »
The pinging sounds like a fueling problem. What injectors? Tune?
99 XJ M62 S/C
x2 on the injectors and fueling mods. What gas are you running? With your 9.6:1 CR you shouldn't be pinging with the 68-232-4 cam.
kkchevy3
Vehicle Year: 1991
Post by kkchevy3 »
using the mustang 24 lb, and i was running the 68-232-4 cam. now running the lunati voodo. I guess ill buy the new o2 sensor for the wideband and figgure out what the mix is
Brandon_K
Vehicle Year: 1999
Post by Brandon_K »
Did you ever get a resolution on this?
