TB guy
Stroker Displacement: 4.9
TB guy
Post by jsawduste »
Whom was the member that was selling bored throttle bodies ? Had a web site that had TB and adjustable FPR`s.
My search skills suck today.
Re: TB guy
Re: TB guy
Post by jsawduste »
Bingo Silver !! Found it while trying some search words. Thanks for the help.
When the stroker was built the idle was a bit off. The engine seemed to load up on decel and idle. Taking the advice of Bennie I drilled a small hole in the throttle plate to pass a bit more air. It fixed the problem and all was good.
Did your crank sensor mod (which I am still very happy with) and am now finding that idle to be a little off. Want to start with a virgin throttle plate and tune the engine from there.
What I have found is that I may have drilled a bit oversized hole in my TB plate for closed throttle operation and the advanced timing.
If you still have my number give me a call sometime. Like to talk Apexi with you.
Or perhaps shoot me a PM with your number and a good time to call.
Thanks all !!
