I have to tear down the engine this week/weekend to see what is ruined. Any chance my new crank/rods/pistons/bores survived this?
As mentioned no knocking, good power etc just got noisy.
-R
I suspect your problem might be the cam bearings. If the oil holes weren't properly aligned in the block, the top of the engine would be starved of oil.superstingray77 wrote:Changed oil again, metal present... removed valve cover and found metal on rocker bolts, and metal colored + new oil laying on top of head. Sadly i fired it up without the valve cover and notice zero oil getting to the top of the rockers/pushrods were dry. At this point shut down and removed cam sensor and installed my drill motor primer on the oil pump. (gauge showed good pressure and goes up linear with drill speed to almost 3/4 way up gauge) (have actual gauge not BS switch that just sits in middle no matter what) still nothing to the top.
