4.7 stroker 99 wj- off idle stumble
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Re: 4.7 stroker 99 wj- off idle stumble
Post by jeepman »
Your Creating BS and Have you actually metered a Factory Fuel system the pressure drops off as The RPM'S go UP so it is LEAN at WOT...
Sorry I am not a person who creates false DATA...
Nothing is exact and my MPG is based on my ACTUAL FUEL CONSUMPTION since you can't read english...
If your "WORD" was correct I would not make it 200 miles on my 22.5G tank and I would have clouds of smoke out the tailpipe but again THAT IS NOT THE CASE which means your WRONG...
Threatening to ban me is a Cowardly way to go because someone does not agree with you, NIce Moderator Job your doing I am sure your proud...
Good luck
:cheers:
jeepman wrote:Your Creating BS and Have you actually metered a Factory Fuel system the pressure drops off as The RPM'S go UP so it is LEAN at WOT...
Yes I have, and no it doesn't drop off unless you have a faulty pump. Fuel pressure stays constant and in WOT it will go rich.
Its not that I don't agree with you its that you are just plain wrong on nearly everything you have said.
Closing thread as this is becoming a fight and not helpful.. to each thier own..
For future readers, please take into account the words of many more than the words of the few.
Locked
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 12 guests
