Well you start with a block of aluminum..........
and you start drilling, turning and milling
till you end up with this....
But then I wouldn't of had an excuse to play with my mill and lathejsawduste wrote:That real nice but the stock sensor location(s).Theromstat housing, back of the head and the side of the block, drivers side just above the engine mount might of worked also. The block is tapped 3/8 NPT and a sender simply screws in place.
The Renix 4.2`s used that spot for a temp sensor and the hole is carried over to the 4.0`s.
