604's double 4.6 build
Re: 604's double 4.6 build
Make your own solid pin out of a bolt. Just buy a long bolt and cut off the head and threads. Grade 5 bolt is fine.
Retlaw01XJ
The stock cam bolt can be used. If you need to buy one, the local Jeep dealer can order it. Also sold by Hesco for more money.604rail_king wrote: where can i order a solid pin/bolt set?
For the pin, I used a dowel pin. Don't recall if it was 1/8" or 3/32" tho. Might find one at the local hardware store in those drawers of misc hardware.
Walt K
Eastern Pa
Eastern Pa
604rail_king
- Vehicle Year: 1995
i saved the cam bolt off my 99 and 91 motors, so thats a plus. i should ask my machinist what he uses for solid pins.Retlaw01XJ wrote:The stock cam bolt can be used. If you need to buy one, the local Jeep dealer can order it. Also sold by Hesco for more money.604rail_king wrote: where can i order a solid pin/bolt set?![]()
604rail_king
Comp 201 cam/lifter kit, SS magnum 2.02/1.62 valves, and some DEI gold heat wrap for the bottom side of the intake manifold arrived today. valves looks awsome! ill post pics later
ill be packing up the rest of the bits tomorrow to take down to my machine shop.
on friday we're tackling the heads! after reading a few threads on diy porting jobs, i think we plan to mainly do more polishing than removing material. taking out the imperfections and ensuring theres smooth transitions. enlarging the ports on our 7120/0630 heads will just push the power higher up in the rpms, compared to the small port later heads... which we are not after.
604rail_king
wow ok took a big vaccation on the builds ... got distracted a bit and couldnt spend enough time on the heads. getting back on track ! both heads are nearing done, just have to clean up the combustion chamber. then do the finishing polish. DAMN ITS A DIRTY JOB!
my machinist has also informed me they may be closing down for a bit as they are extremely slow these days. the company is primarily a parts warehouse with the machine shop on the side but i guess the industry is hurting. we were wanting to complete heads with magnum valves, then cc the heads, and use the final figures to machine the block according. but thats changed with the new schedule with the build.
initial block decking calculations were to use a final height of .010. this would yield us on the higher end of the spectrum with our safe compression goals however to speed up the process we are simplifying the machining and going with only .005. it allows our machinist to finish up the short block should they decide to close up for a bit... then assemble the rest at home!
604rail_king
been a while! however ive been spending some time on the strokers again - mainly cleanup, painting, ect. i have pics along the build that im saving so i can build a better timeline.
everything is all machined and short block assembled. i measured the head cc's today and came up with about 61-62 cc which sounds about right with running the magnum ss valves and considering how much was machined off the head (only a few thou). ill make some assembly progress when a friend drops off his cam degreeing tool.
when i plug all the info into the stroker calculator, i get approx 9.0 SCR, 7.7 DCR, .059 Q.
(comp 201 cam degreed @ +4)
sounds very pump gas friendly to me.
thoughts ?
thoughts ?
jeep7081
- Learning to use the board
Part #'s for Magnum valves and springs? Or link604rail_king wrote:ordered 2.02/1.62 SS magnum valves and Comp 201 cam/lifter kit. should look all pretty with the Rollmaster timing set. i got side tracked with re-outfitting my garage with new warehouse pallet racking, and buying a 8.25 with locker.
talked to machine shop today, blocks are going up next for bore/hone/ect. crank has been machined. rods/pistons/arp have been installed, balanced, and shot peened. ill still likely need to order new push rods
i quickly threw on a new spare felpro exhaust/intake gasket to the heads to see how much porting work is ahead of me. the intake ports are almost a dead match. exhaust can be opened up a decent amount. ill see how it compares to the Victor gasket
after porting and final decking, we're expecting to end up on route with 9.45 scr, 8.05 dcr, .053 quench
604rail_king
Only used the magnum valves. Still on stock springs
http://www.ebay.com/itm/390495170308?redirect=mobile
