TPS and IAC wires
gmakra
I think I'll order a "tab"
TPS and IAC wires
Post by gmakra »
Gents I am installing a Weber Redline MPI on my 85 CJ stroker. I have a Jeep 2000+ intake with a 63MM throttle body and I have everything figured out except wiring the harness into the IAC and TPS. Both connectors have black with a trace color so I am assuming hose are the grounds. The TPS should be easy since ones a supply voltage and the other is a reference signal so if it dosent work switch the wires.
The IAC will have three wires along with a ground can anyone shed some light onto what wires or pins on the connector do what?
gmakra
Re: TPS and IAC wires
Post by gmakra »
Ooops I meant 62 MM
