Air fuel ratio meter needed??
knever3
Learning to use the board
Vehicle Year: 1987
Post by knever3 »
I have a 4.7 stroker for my Comanche, '96 block and head, '99 intake and throttle body, Ford 24lb injectors, renix wiring and computer.
What do I need to keep track of the engine?
Adjustable MAP?
Wideband air fuel ratio gauge?
Let me know what I need and why if some of you guru's can chime in.
Thanks!!
Re: Air fuel ratio meter needed??
To truly see whats going on with the engine you need a Wideband 02 Sensor.
As far as tuning, you can only use a Adjustable MAP and Adjustable FPR on the RENIX, so as long as you have the right size injectors you should have no problem tuning.
I have a RENIX with a 4.7 and i started with 26# injectors. They were way to large. I dropped down to 23# and they are still a bit large. Ive thought about dropping down to 21#.
Every engine is different, so you will need that Wideband to figure out what needs to be done with yours.
Users browsing this forum: Amazon [Bot], Bing [Bot], Semrush [Bot] and 4 guests
