160 Degree Thermostat
Coffee Commando
Thoughts on this? I haven't heard of anyone ever running one. Is this too cool?
Re: 160 Degree Thermostat
No
- IH 392
If you're overheating at 190* you'll overheat at 160* too.
It IS if you want your heater to blow warm air in the cold winter months. Unless you live in a country near the Equator that has a warm climate year-round, I wouldn't recommend going lower than a 180* t'stat if only so that you can have decent heater function in the winter.Coffee Commando wrote:Thoughts on this? I haven't heard of anyone ever running one. Is this too cool?
Coffee Commando
It doesn't get that cold in Florida. So if I maintained this temperature via electric fans and spoof'ing the ECU into turning on the auxillary sooner with the resistor trick would this increase the HP due to a cooler combustion chamber?
Is there a complex formula for roughly guestimating detonation based on DCR with engine temperature?
No, it would just increase engine wear.
Possibly but keeping the engine running cooler than normal could increase emissions, oil contamination, and engine wear so is it worth it?Coffee Commando wrote:It doesn't get that cold in Florida. So if I maintained this temperature via electric fans and spoof'ing the ECU into turning on the auxillary sooner with the resistor trick would this increase the HP due to a cooler combustion chamber?
Retlaw01XJ
One of the guys posted a chart showing the relationship between engine temperature and octane requirement ..... January- February perhaps?Coffee Commando wrote: Is there a complex formula for roughly guestimating detonation based on DCR with engine temperature?
Walt K
Eastern Pa
Eastern Pa
woodjeep
160 is way to cool...I ran a 180 for a while and at highway speeds it would be at the 1/2 hash mark between 100 and 210...you will always run rich if you use the 160..possibly ok if a hot climate for the 180. I have a new dirk radiator and the NAPA clutch fan...I run a MR Gasket hi flo 195 and it stays at 195 in all but the most extreme traffic conditions... my aux fan almost never kicks on and i don't think I ever pass the 210 hash mark
shawnxj
- I love this board
don't know about the jeep but i have a 160 in my truck and it runs about 135 to 140 year round.....heater gets plenty hot during the winter and i have 309000 miles on the motor. tstats been in since about 20k. i did notice my mileage went down a little but the power went up. i lost maybe 1 to 1.5 mpg
Too cool.
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 4 guests
