I'm building my stroker to be more efficient & run like I want it to. I'm thinking of keeping the stock cam, but also thinking of adding a cam that will offer a little more down low while loosing nothing up top. I love how my 87-95 single pattern cam can hold the power to 5300rpm, but I'd like more down low. Jeep will weigh around 5000lbs give or take a couple hundred all said and done.
Cruising will be around 1900-2100rpm pending speed. Motor is intended for a daily driver, expo/camping rig & its a 5speed. I'd like more down low to keep it idling over stuff, but also be able to hold the power to 5300rpm. What are my options here? Dino what do you recommend?
I was told about the Crane cam #753901T, grind #H-260-2? I was also thinking of installing my current 87-95 cam a few degrees advance to have it come on sooner? I know it holds power to 6000rpm which is not needed, so what about installing it at -6 or -4 vs the stock -8 degrees? Would that get me some more lower end?
Dezertxj88 wrote:I was told about the Crane cam #753901T, grind #H-260-2?
That cam is the same spec as the Crane 753905 that I originally had in my stroker and it was a great choice (for the 34k miles that it lasted anyway) with a nice spread of torque. Anyone looking for more torque lower down the rpm range could go for the Crower 44243 but you could just keep the stock 87-95 cam and get similar results by advancing it 4 degrees.
And with the stock cam advanced dino what would my DCR jump to?
"That cam is the same spec as the Crane 753905 that I originally had in my stroker and it was a great choice (for the 34k miles that it lasted anyway) with a nice spread of torque. "
My new stroker is going to receive one of the wide-lobe MOPAR performace cams... Many of the aftermarket cams only have lobes that are 1/2 inch wide... Stock cams and the MOPAR perf. cams have wide lobes that are 11/16 of an inch... They also allow the use of stock springs, and seem to last a long time. The 228 or 229 Mopar cams are great for low-end grunt !!!
Smoke 'em wrote: The 228 or 229 Mopar cams are great for low-end grunt !!!
My dyno simulations did reflect that, but unless you're building a mostly or dedicated off road engine the stock '97+ cam was still better for the street, it's to bad they discontinued the "30AB" cam, it was better yet.
