HELP fuel problem
EVIL95XJ
- Vehicle Year: 1995
HELP fuel problem
Trying to fire the stroker. I have no fuel pressure on the rail. I remove the FPR and get sprayed by fuel?
Ford 24# injectors - PM me
Re: HELP fuel problem
Rent a fuel pressure gauge from auto-zone or advance auto. Plug it into rail. Turn ignition on and then go look at the gauge. If you do 2-3 ignition on/offs, you should see it get to 39psi +/- a few. If you see it dropping fast, then you have a bad check valve or leaky injector.
